Page 1 of 4 123 ... LastLast
Results 1 to 40 of 146
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Hello EPL E85 Stage 1
    $15 fill ups rock!!!!
    Oct 14 2012
    Empty...for now...
    SE PA
    When running full E85, what happens to your normal daily driving fuel efficiency? Let's assume your driving habits do not change versus when you are using 93 octane gasoline. I'm wondering if there is an overall cost savings going this route, or does the engine burn through E85 a lot quicker and therefore total long-term cost is a wash.
    SOLD 2015 Daytona Gray S4
    Nov 12 2015
    Here
    [IgnorantQuestion] Can the fuel system (pumps, injectors, lines, etc) on these cars handle E85 long term? [/IgnorantQuestion]
    Mein ist grau
    Nov 16 2015
    DFW
    You will probably get 2-3 mpg less on avg
    Nov 16 2015
    DFW
    Quote Originally Posted by SportVier View Post
    For stage 2 you need a HPFP upgrade. For stage 1 stock fuel system is fine
    Oct 14 2012
    Empty...for now...
    SE PA
    That's a great question. I see various domestic vehicles driving around with a "Flex Fuel" badge indicating to me that they did something special with the guts to accommodate ethanol for long-term use.
    Quote Originally Posted by GRUMPY-S4 View Post
    That's not bad at all! Seems like you would definitely come out ahead, depending on how long you run that way versus the cost of the E85 tune.
    Nov 16 2015
    DFW
    Quote Originally Posted by SteveYem View Post
    Yea they fitted those cars with the right FPs/Injector combo to handle the added flow
    Nov 16 2015
    DFW
    You are aware that its not only to save on fuel right???
    Power plus cleaner valves more than make up for it as well. Race fuel power at 91 cents a gallon??? Where do I sign up???
    Established Member Two Rings Tod's Avatar
    Jan 13 2016
    Nw burbs Chicago
    Question?
    We have E85 all over locally, if I'm out and about and run low and need to fill up. Is 93 okay? Any adverse effects running 93 on E85 map?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2012 Prestige, TI package b8 S4
    Past fun,
    2008 SRT8 Jeep pwr 440 Blown by Vortech
    1996 Eclipse GSX bunch of crap
    1996 Slp SS 383 Blown by Vortech
    Nov 12 2015
    Here
    I was not asking about flow but longevity. Polymers breaking down over time and what not.
    Mein ist grau
    Nov 16 2015
    DFW
    Quote Originally Posted by Tod View Post
    Question?
    You need to switch the map. As far as I know... Since fueling would be all different
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Fuel never touches the valves.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 16 2015
    DFW
    Evo guys run it for years with no issues
    Nov 12 2015
    Here
    After swapping in an Audi fuel system...?
    Mein ist grau
    Nov 16 2015
    DFW
    Meaning Rubber these days withstands the added "swelling" E85 can cause.
    Or does Mitsu use different rubber than Audi lol?
    Rubber is Rubber
    Nov 16 2015
    DFW
    Quote Originally Posted by LINDW4LL View Post
    But Carbon buildup would be less????
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Hey Grumpy what was your OTD cost for stage 1 e85? (I know you got in on the group buy) You can PM if you want...
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Nov 12 2015
    Here
    Rubber is Rubber
    Rubber is Rubber. "lol", indeed.
    Mein ist grau
    Nov 16 2015
    DFW
    Hey man then dont run it...
    People running dual Pulleys are pioneers... E85 is nee also on this platform.
    Other cars have been using it for a while. What do you want to get at then? Evidence of longevity... Doesnt exist on this platform
    Oct 14 2012
    Empty...for now...
    SE PA
    Yes understood 100%. I was simply trying to understand whether it is an economically viable solution for long-term, daily use, i.e. always filling up with E85 as opposed to doing it only for occasional fills before drag strip visits, etc.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Congrats on getting it done... Hows the newly installed sensor working? I might end up running it if I can find a E85 station close by...
    Nov 16 2015
    DFW
    I think it pays for itself in about 6months (assuming a fill up a week)
    Nov 16 2015
    DFW
    Quote Originally Posted by HeymyA4 View Post
    Love the sensor!!!!!!
    Currently running E40...
    Took the car out today and spun all 4 wheels lol
    Sep 23 2006
    Las Vegas, NV
    Uggghhrrrrr!!! The need more E85 stations around me!
    Jul 21 2004
    South Florida
    Not really. Its direct injection into the cylinder so never touches the valves. Spraying meth at the valves could conceivably help but even some N54/n55 guys who daily drove meth cars are saying it looks like it did absolutly nothing to prevent the carbon buildup :(
    The reason to run E85 is for the power you can make. It is a great fuel for knock mitigation.
    The bummer about it is that it gives significantly worse fuel economy (20-25%) and MAY erode parts quicker that were not specifically designed for it and some dont like the smell. I'd probably try it too if we had any near me.
    Mike
    2018 Audi S5
    Gone-
    Nov 16 2015
    DFW
    Quote Originally Posted by bhvrdr View Post
    Mike
    Somewhere I read that the carbon buildup from E85 was less...
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello Grumpy,
    Thanks for the info about the HPFP needed fot stg2 and not for stg1, didn't know, verry interresting !
    You run a E85 tune right ? with only E40 ? isn't there a minimal amount of ethanol needed to run E85 tunes ? (i though it was ~ E70)
    BTW, i am verry jealous that APR doesn't offer E85 tunes (yet ?) . Hope they did not gave up the B8/B8.5 Platform...
    Best regards,
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 16 2015
    DFW
    Quote Originally Posted by Mat@1975 View Post
    Hello Grumpy,
    Best regards,
    Mat
    I run E40 on the regular stage 1 EPL tune (dyno'd 70hp over stock)
    I just got the E85 tune today. Still not running it. For it I would need full E85. Will be dyno'ing soon to see difference.
    Jun 14 2015
    FRANCE
    OK ! thanks.
    Did EPL specified a minimal content of ethanol in order to run the E85 tune ? (we know that it's sometimes not as much)
    Other question: if you plan to run your E85 file and fill with crappy E85 that gives E60 or so, witch map do you load ?
    It seems that an intermediary map (ie. ~ E50-E60) would be needed to handle all situations ?
    BR
    Mat
    Nov 16 2015
    DFW
    OK ! thanks.
    BR
    Mat
    Thats a great question Matt!!!
    I will ask Tony as now Im curious myself!
    Jun 14 2015
    FRANCE
    I am curious about the answer too!
    Asuming That:
    1. ~E40 is the maximum Ethanol Content to run with regular fuel Stage 1 tune (before throwing lean CEL's)
    2. ~E70 is the minimal Ethanol Content to run with a E85 tune
    ==> there is a no man's land between E40 and E70 ...
    I asume that the only startegy is to not do complete fill at the pump, then let the zeitronnix measure, and then continue filling with E85 if the Gas is good, otherwise complete with 93 in order to return Under E40... Not simple !!! ;o)
    BR
    Mat
    Nov 16 2015
    DFW
    Asuming That:
    BR
    Mat
    I believe you wont get Lean codes until after E50. I have run E45ish and no issues. Probably no gain after E30 aside from on your wallet.
    Jun 14 2015
    FRANCE
    Wow, E50 is a lot !! i think other have report less threshold...
    I aknowledge that beyond ~ E30, depending on your tune aggressivity, you won't see Knock activity, thus max possible timing, right ?
    THanks a lot for sharing !!
    BR
    Mat
    (Zeitronnix sensor on the way ... ;o) )
    Nov 16 2015
    DFW
    BR
    Mat
    Yeah I see no knock and timing in the high teens
    Jun 14 2015
    FRANCE
    Only timing in the high teens ? what is your red line ? (i toped at 27-28° at 7200 with APR stg 1 with 3.5 gals of E85)
    It seems that you have room for additional performance !
    looking forward to looking at your new timing values with the E85 tune !! Perf improvement will be great !!!!
    BR
    MAt
    Nov 16 2015
    DFW
    You sure you werent on Race gas??? Actually my timing was 20-21
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    BR
    MAt
    27 or 28 degrees seems really high for a non-race gas map. I haven't seen the APR 104 octane race gas file get close to those numbers. Maybe there is something vastly different with stage 1, but that is a hell of a lot of timing.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Nov 16 2015
    DFW
    Isnt there a point where Extra timing is counter productive?
    Jun 14 2015
    FRANCE
    Yes I am !
    Fellow AZT had the same results with the revised APR stg 1 tune.
    You can see the story here:
    http://www.audizine.com/forum/showth...1#post11137148
    See you !!
    Mat
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Yes I am !
    See you !!
    Mat
    I remember that thread, and your logs and graphs. For some reason I thought you were hitting 24 degrees on the 93 (98 RON) map, but pulling a lot of timing. Then you switched to the 91 map (95 RON). I was thinking your timing would be lower at that point.
    That is just really high. Can you post the raw log file when you get a chance? I'd like to take a look at it.
