Results 1 to 29 of 29
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2step on stock clutch
    Yup, I have an A4. Don't like it? Don't respond.
    I'd like to activate 2step on maestro and have a little more fun this summer. The thread is posted here because I have a stock b5 s4 disc and PP in the car.
    I'm basically wondering how the clutch will hold up to launch control and if it is stout enough. My car isn't crazy, about 280awtq and 320awhp. Breaking stuff doesn't really matter because it isn't my DD, but I'd hate to activate the 2 step just to find out the clutch gets smoked ever time. Just looking to have a little fun and take it to the drag strip a time or two.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    You will kill it.
    Mine only did 3 or 4 launches at stage 2+ methanol before it couldn't hold a launch anymore. These weren't back to back either, just for a few weeks leading up to stage 3 and the motor was coming out anyway.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    what he said ^ ruined
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Damn, looks like I need a quality setup for fun stuff.
    FWIW, the clutch has had up great so far, but I do not abuse it at all and my boost comes on gradually.
    2000 S4- Working?
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    My buddy did about three launches before one of the pressure plate fingers broke and got jammed.
    Don't drive too close to the sun on pressure plates of wax
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Zba View Post
    I should note the whole unit only has 20k on it. Not that it has been babied, but I have never launched it before.
    2000 S4- Working?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Fuck it. Let er rip nigga.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Do it
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by CELison View Post
    Quote Originally Posted by Peter1.8t View Post
    Do it
    Hmmm... I suppose we could see what happens if I did.
    2000 S4- Working?
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    I got 3-5 decent launches out of my stock clutch before it literally disintegrated. I was only stage 2... they unbuttoned the trans and they said clutch bits fell out. FWIW.
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    I doubt it would survive continuous 2-step launches, but I don't think it would melt right away. Your car is making a lot less torque than tuned 2.7's do.
    Sep 11 2009
    NE
    I don't think it has to do with TQ but with trying to mate 4-5k rpms on one side with 0 RPMs tranny while continuously slipping until tranny reaches the RPMs . At best it will burn the clutch which you can easily tell by resulting smell...
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by julex View Post
    The trick is to lock the clutch and get the tires spinning a bit.
    2000 S4- Working?
    Sep 11 2009
    NE
    Quote Originally Posted by redline380 View Post
    which with stock clutch won't happen
    Nov 02 2014
    Winchester, VA
    Without the torque the trans would just bring the engine down near it's level and meet somewhere in the middle. But I do agree, his motor will just overpower the clutch.
    That said, this was on the stock clutch.
    Only got to do that a few times. The last time I tried, the car lunged and then the engine just freewheeled. Like I said I think it was on the 4th or 5th launch that the clutch just said "fuck it I quit"
    Still held fine otherwise for a few weeks, but like I said I was replacing it anyway so I wanted to see what it could do.
    Edit: just watched that video for the first time in a while, crazy the difference from then to now.
    Sep 07 2012
    Tucson, AZ
    Go big or go home.
    Nov 05 2009
    Denver
    Quote Originally Posted by LightningLou View Post
    Go big or go home.
    Go big AND go home (on a flatbed)
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Well if it does go out you could always drop in a B5 RS4 clutch. Mine holds fine on Stage 3 power lol
    LOL this made my day. b5 s4 life at its finest haha
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Nov 05 2009
    Denver
    Quote Originally Posted by Wagonholic View Post
    It's my family motto!
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    ^^^LOL. A day in the life!
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I 2nd this motion.
    I dont think 1.8s have quite the gunt that the 2.7s have down low so you might get away with it.
    If you do run into trouble, my guess is it will be the facings coming apart because of how they are riveted on.
    They dont have a metal backing like aftermarket disks so nothing but the fric material for them to grab onto.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Here's my dyno, not very impressive until you get well into the rev range. Obviously I wouldnt be at full boost at launch.
    This car has never been on a flatbed luckily. I did break my stock PP into three pieces, but I was only a mile from home and was able to limp it back
    2000 S4- Working?
    Veteran Member Three Rings EMF614's Avatar
    Jun 15 2011
    cbus
    stock s4 clutch will get wrecked faster than this country if trump is elected
    Ethan
    Single Turbo B5 S4
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by EMF614 View Post
    So my clutch is going to be better than before since I installed it during Obama's term? Awesome!
    2000 S4- Working?
    Nov 16 2010
    WetSide, WA
    Did you sign up for ObamaClutch?
    If you like your clutch, you can keep your clutch
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    FREE CLUTCHES FOR EVERYBODY... I'm just trying to represent Bernie over here haha
    Dec 03 2009
    PNW, Washington
    We are all horrible influences. We destroy our own cars then try to carry out more destruction vicariously through forum members.
    Nov 16 2010
    WetSide, WA
    But he be havin a 1.8 so I think there is enough room to just slide a new disk in without sawzalling the car in half first like an s4?
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Quote Originally Posted by zillarob View Post
    Not sure if no one else got this, or if I'm the only other one here who still does Obama impersonations telling people if they don't like something, "well, then you can, ugh, keep your old one."
    Bravo zilla, my man-crush I have on you just doubled.
