Since this thread has been revived, I still have the following:
Here's the short list off the top of my head:
ECU box (top & bottom)
Entire trunk interior including trunk lid cover
Toolkit w/ jack (have to check condition and contents)
Imola Hood
Imola Door skins (all but pass rear)
Rear window glass (tinted and in perfect condition)
C-Pillar glass (driver's side only)
Driver's side rain gutter (the long dark anodized aluminum piece)
Set of front seat mount covers (black plastic)
Rear seats (not that great of shape) Headrests good, tho.
Rear deck speaker covers intact (2 driver's and 1 passenger)
Entire Radio harness (only wires cut are for the rear door speakers near the yellow plugs)
Bose Amp
A/C Compressor
Alternator (120A)
Aluminum Part that the UCA bolts to (just 1, should fit either side, looks like a hat)
Front subframe
Aluminum engine mounting brackets - 1 set
Stock fuel rail with injectors (10.5k miles)
Stock K03's Pair (passenger is bad for sure with 1 missing exh. fin)
Passenger side cylinder head (incl. good valves, springs, etc. NO EXH CAM OR EXH LIFTERS OR COVER)
Accordian Hose (brand spanking new with clamps)
Little sun visor in front of rear view mirror
Interior light above visor (only have 1)
HVAC Unit (complete w/ heater core and blower motor) This isn't the controller below the radio. It's the huge unit behind the dash.
Radio surround (upper center console with mounting hardware for radio,etc.)
Washer fluid reservoir (perfect cond.)
Lateral side airbag sensors x2(mount under the seat area)
Steering wheel (no airbag) decent condition
Front brakes with rotors and small dust shields (I'll sand blast the iron components prior to sale to clean them up perfectly)
1 Avus wheel that is sideswiped (with Stock 70% Bridgestone), but has no gouges or lip damage)
Steering column w/ key
E-Pedal (gas pedal)
Aluminum mounting piece that pedals, master cylinder and steering column bolt to.
Brake and clutch pedals
Front bumper bracket/shocks (1 set)in perfect cond.
Rear bumper bracket/shocks (2 sets)in perfect cond.
Antenna amplifiers (all 4)
Driver's side door sill (w/ aluminum S4 inserts)
Stock springs (all 4)
Stock rear sway bar
I diligently respond to email inquiries to
[email protected].
Shipping/Pickup point = Pittsburgh, PA area
Thanks
