Results 1 to 4 of 4
    Junior Member Two Rings
    Nov 16 2015
    Netherlands
    Question Route cable from trunk to middle console
    Hello,
    A few weeks ago I bought myself an AccuAir set. But now the only thing that's left for me to do is to route the cable from the trunk to my middle console. In the manual from AccuAir there is just 1 small photo and they want you to remove the backseat and route the cable underneath the carpet to the middle console, but not much info or photos.
    Does anyone knows a DIY with photos or so for me?
    Many thanks!
    Dweep
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    In my opinion you dont need photos for doing this. Just take your hands and remove all the plastic :) Sure it can be abit tricky with the airbag next to the backseat but shouldent be a problem. To remove the glovebox there is guides out there and i recommend that because there is 10000 screws.
    This is easy as hell, you are just abit scared and i understand you :)
    Here you go. Just follow this http://www.ozaudi.com/forums/a4-s4-r...-graphics.html
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by endy1 View Post
    I think that DIY is a little overkill. All he needs to do is go under the rear seat cushions, under the carpet, under the center console and up.
    You can use the oCarbon DIY to dismantle the center console. It should be pretty easy to get there from the trunk.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    May 04 2014
    Sweden
    Quote Originally Posted by adamazing View Post
    The centerconsole took me forever to remove. That one is even worse then the glovebox :D But i guess he wants the remote in the centerconsole so maybe your way is better/easier.
