Results 1 to 4 of 4
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Just ordered JHM rear 2piece rotors, Hotchkis rear sway bar & 034 end-links
    Hey guys,
    Just ordered JHM rear 2-piece rotors, Hotchkis rear sway bar & 034 end-links. I can hardly wait to get the stuff over to the EU and throw the car around the RedBull ring next season!
    I'm getting the front rotors & bells from AP Racing (already ordered last week - back-order is 9-11 weeks.....) and a 12 pieces of Ferodo DS2500 pads (without the sensors at the front).
    I searched a bit for a DIY on the Hotchkis rear-sway installation and only found them in the A4 forums, but the job is pretty much straight forward if I'm not mistaken or is there anything special to worry about?
    Although I do remember a forum post a while ago where there was a bar pictured and the 034 links were installed upside-down or something like that?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Thanks for the order!
    Yeah, the sway bar is pretty straight forward!
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    Sway bar very easy!
    Sent from my iPhone using Tapatalklk
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Love that sway bar. I have HSports on my s4, I think the rs4 is still on the stock bar. Totally helps the car rotate in the corners to dial out that understeer, I've had it up on 3 wheels a couple times.
