Results 1 to 3 of 3
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    B8 A4 Water Pump and Timing Chains and Guides and more!!!!!! - No Longer Available
    I have for sale a few B8 parts. Please read full descriptions carefully.
    1) Selling a used water pump and timing chains for b8 a4 2.0t engine.
    There is absolutely nothing wrong with the parts other than normal wear, only replaced because I did a full maintenance on the engine and since I had them apart I decided to give it all new parts.
    I spent over $1500 on new audi chains, and water pump, etc. Im asking $300 shipped.
    I will accept returns if you a have reasonable request, based on my approval.
    Check part numbers to make sure they fit your vehicle. Not responsible for wrong installation or user error, please check with dealer for any concerns.
    The water pump includes thermostat, and other temp sensor, just the way i took it off the way I will ship it. Again, It is in good condition, only replaced it because I wanted a new thermostat and decided to replace everything. Unnecessary on my parts, but at least I know these parts are still good.
    The two timing chains are not worn at all, no sign of wear, the guides that you see on the photos are not for sale because I recommend changing them with new parts but you can have them if you want.
    Kit came off a 2010 a4 premium plus with the 2.0t engine.
    The tensioner was also replaced, and I recommend replacing this part with new updated part.
    Everything above selling for $300 (Timing Chains, water-pump with thermostat and sensor)
    If you have any questions, contact me.
    WATER PUMP
    TIMING CHAIN
    06K-109-158-AD
    06K-109-158-A
    06H-121-026-DD
    2) Two Front floor mats, carpet, black. best offer $$
    3) Garage Homelink control. Goes for a lot at audi, if you need it, I will take $100 for it.
    4) Stock fog light bumper covers. They are in good condition, no broken tabs.
    5) Selling new and used front lower control arms and more. See photos for details.
    I have two kits for the front control arm for the b8 a4, a5, q5 2009-2015
    One kit is brand new, and fits the cars with the m12x1.5
    The second kit is my old kit that i replaced. You can replace the bushings and you'll be all set. Size is m14x1.5
    Price is best offer!
    Also selling oem sway bar links, and one TRW oem ball joint.
    See photos for details and condition of parts.
    8K0407510A, 8K0407509A, 8K0407506A, 8K0407505A, 8K0407693R
    8K0407151F, 8K0407152F, 8K0407151D, 8K0407152D, straight arm
    8K0411317E, sway bar link, by febi
    8K0407693R, 8K0407694R, lower control arm, curved, m12x1.5
    8K0407694S, 8K0407693S, lower control arm, curved, m14x1.5
    8K0411317D, sway bar links, by Lemforder
    I tried to give my best description of the sizes of the control arms. Its your responsibility to make sure they fit your car.
    Ball joint for sale:
    OEM: 8K0407689G
    By TRW
    Genuine TRW OEM front lower ball joint, used but in good condition. See photos for details.
    Thanks for looking!! Photos coming soon.
    List Date: 2/12/2016
    For more info, click here to view the original listing: B8 A4 Water Pump and Timing Chains and Guides and more!!!!!!
    This item is no longer available.
    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    How much for the fog grilles also how do you tell which control arms your car has?
    09 Prestige Package
    Mar 15 2012
    Quote Originally Posted by Black_Pearl_B6 View Post
    give me an offer for the Grilles.
    also, i would check your VIN. but they are either m14x1.5 or m12x1.5 so i would look at the curved lower control arm and see if it is the thicker balljoint or the thinner one? Not really sure, but since i ordered the wrong parts at first, now i know. lol
