Results 1 to 20 of 20
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    Launch Control Help
    Ok I'm being an idiot and can't engage launch control. This is what I'm doing and I'm sure there is something I'm missing....turning the traction control in sport/full off (doesn't matter), putting my left foot on the brake, and mashing the gas. The RPMs however only go to 2000 and won't go any higher. What am I doing wrong?
    Aug 06 2012
    san diego
    a3 or s3?
    Apr 15 2010
    Quote Originally Posted by markn1689 View Post
    a3 or s3?
    S3....just realized my signature isn't working
    EDIT: So if I post from the mobile site it doesn't post my signature, strange
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
    Aug 06 2012
    san diego
    wheels straight
    engine warmed
    in S mode
    traction off
    brake fully pressed
    accelerator fully pressed
    you should see rpms bounce at 4k
    then release brake
    Apr 19 2015
    Yes and make sure it's in dynamic mode and it's ESC OFF.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Apr 15 2010
    The car was still cold. Cold that be the culprit? I didn't check the engine temp but it had only been on for maybe 5 mins.
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Aug 06 2012
    san diego
    Quote Originally Posted by fhwang View Post
    i dont have to be in dynamic mode. i could be in comfort mode so long as i put the tranny in s mode. will still launch fine
    Aug 06 2012
    san diego
    Quote Originally Posted by Speedybrit View Post
    try when its fully warmed? do you have a vcds? if so you can add the oil temp gauge in DIS. fully warmed is about 200-215 degrees F
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    So why would someone launch a cold car? Just seems like extreme punishment if the car is not adequately warmed up.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yes. Why would you attempt to launch a cold engine/drivetrain?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 06 2012
    san diego
    i remember reading an article about porsche testing their cars in 0 below degrees. they would let the car sit in 0 below for a day or longer, then hop in, start it and start driving super hard.
    the car CAN handle it. and it will run faster because the air is more dense and the turbo will spool more air. i remember this being especially true in my old b5 s4. it was incredibly faster when cold.
    im in cali now and not really interesting in that anymore. i usually drive pretty gingerly. especially until it warms up. but i'm not afraid to give it some stick after a fresh startup
    Apr 15 2010
    So I tried it again once the engine was in the 200 degree range and it works as expected now. I wasn't planning on launching the car cold I was just messing around trying to figure the launch control out.
    Apr 15 2010
    I decided to bring up my old post rather than make a new one. So I haven't used the launch control in a while and was messing around with a friend in the car last night and we tried the launch control. I remember it used to hold the revs and boost near "max" but last night it just didn't seem right. The car had been driven for almost 30 minutes before we tried it, temperature was around 200, esp was fully off, dynamic mode and in manual. All the same as the last time i used LC. I attached a video to show what I'm talking about, I feel like the boost should be being held more than what it is. Could there be a leak somewhere? Could the temperature outside affect LC? Car is stock other than intake and resonator delete.
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Jul 20 2009
    2001 A4 Stage 3+
    Spokane, WA
    Try it in Sport?
    Apr 15 2010
    Quote Originally Posted by DWP View Post
    Try it in Sport?
    Yepp tried in both sport and manual. Dynamic and comfort (in sport). All the same results.
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Nov 16 2015
    North Jersey
    When I first got my car, I read somewhere that this is normal. I don't know the technical ins and outs of what is happening, but boost pressure isn't held steady during launch control. Someone had suggested that, for a harder launch, catch the boost on the "upswing" when boost pressure is building. Now, i don't know if that's true or not, but it seems logical to me.
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    looks normal to me
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Jan 17 2017
    TX
    I launch it at full boost. Just watch the boost meter. Works every time no probs.
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    Its not difficult to launch.... somewhere along the lines your execution is off.
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by a4000 View Post
    looks normal to me
    Same here.
    Quote Originally Posted by RGT03 View Post
    This.
    Having an engine and tcu tune also help to build up more boost
    For the execution part, on my car I really have to make sure the brake is buried on the the floor for it to activate.
