Results 1 to 2 of 2
Thread: Vagcom cable
    Junior Member Two Rings
    Feb 19 2015
    lancaster ohio
    Vagcom cable
    What is the best cheap vagcom cable to buy and what device do you recommend to use with it. The device will only be used for this purpose. Thanks
    Sent from my SM-G920P using Tapatalk
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    409 cable from ebay and a laptop/tablet.
    Lots of cool stuff you can do with this setup as opposed to buying a scanner that only does 1 thing.
    Tough to see in pics, but this is a dell venue 8.
    Does pretty much everything you can do with our ecu's for less than $100.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
