Results 1 to 4 of 4
    Aug 19 2013
    minnesota
    Funnel to fit b6 coolant tank
    I'm looking for a big funnel to fit the b6 coolant reservoir, any one know where to get one? It would make bleed and filling a lot easier.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    How is it that you can do all of this...
    "Stern Mounts, APR exhaust, 225 injectors, stage II programming, KO4, Samco Tip and inter cooler piping, Hotchkis sway bars, S4 suspension, Brembo drilled rotors, Hawk HPS pads,Southbend SMFW stage II endurance, Gates racing timing belt, Denso Iridium plugs, Motul 8100 Xcess, MANN 950/4 filter, Motul gear 300"
    ... but you can't throw a tape measure across the opening in the coolant bottle and then head to Fleet Farm?
    Really man, funnels are sold just about everywhere. Okay, I know it's cold there right now. Here, you don't even have to leave the house - check out the funnels at Grainger or feast your eyes on some of the best web design out there: McMaster-Carr.
    Jan 09 2012
    MA
    Get one of these. Way quicker that a funnel and pretty much guaranteed no air in system.
    http://www.amazon.com/FJC-43610-Radi.../dp/B00804HWOU
    Aug 19 2013
    minnesota
    Haha I didn't know they had the diameter of the various funnels listed on their sites.
