    Aug 09 2012
    2013 S4 phantom pearl
    IL
    RS4 steering wheel alignment question
    as title says: I've got an alcantara RS4 wheel installed. I'm using an OEM wheel, RS4 airbag/horn mounting bracket, and a B6 airbag. I can't quite seem to get the right side of the bag to sit flush. I've only found one read relating to the same issue, but there was no resolution posted. does anyone know what the issue/fix might be? from what I can tell, everything seems to be clear prior to installing and tightening the airbag screws
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    The thread below might help you out.
    http://www.audizine.com/forum/showth...ng-Wheel-Issue
    Aug 09 2012
    IL
    that's the post I ran across. the last guy to comment asks how he bolted the horn bracket down if it's installed on the wheel, but no answer. that's perplexing to me too.
    Apr 21 2011
    Central NY
    I think he bolted the bracket onto the airbag to see where it needed to be bent to line up and then put the bracket back onto wheel and then installed airbag like normal.
    Aug 09 2012
    IL
    not a bad thought.. I'll give it a shot
