Hoping one of the smart B6 S4 guys or anyone else that may be able to answer a question for me. I have the following codes for a vag scan today and want to know if the are related or separate issues and how serious? The engine runs fine and the temp gauge is normal when fully warm.
Looks like I in for a engine mount change as well.
I am referring to the codes in addresses: 01 & 17 (the others I am aware of and will deal with shortly.
Thanks for any advice or suggestions guys (or gals).
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
www.Ross-Tech.com
Thursday,11,February,2016,17:01:58:64320
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUPL68E84A128542 Mileage: 110900km-68910miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 C HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Coding: 0007771
Shop #: WSC 63351 000 00000
VCID: 2541FB4BEF1A461622-5124
2 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit - Intermittent
19497 - Powertrain Databus
P3041 - 004 - Implausible Engine Temp. Message from Inst. Panel - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E0 910 156 HW: 09L 927 156
Component: AG6 09L 4.2L5V USA 0040
Revision: 00000001 Serial number: 0002862
Coding: 0000002
VCID: 63C5A553A1AEF8260C-5124
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04597
Shop #: WSC 06435
VCID: 36632C0712BC3D8E9B-5106
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1319
Coding: 00000
Shop #: WSC 63351
VCID: 63C5A553F1AEF8260C-5124
1 Fault Found:
01172 - Temperature Sensor; Driver's Heated Seat (G59)
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0617
Coding: 01013
Shop #: WSC 03301
VCID: 35612B0B0FBA369692-4B1A
1 Fault Found:
02104 - Light Detection Sensor (G399)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
VCID: 3F8D49236D86FCC648-5124
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01141
Shop #: WSC 63351
VCID: 3E7334273A8CF5CE43-4B02
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 980 M
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 03200
Shop #: WSC 03301
VCID: 36632C0712BC3D8E9B-5142
WAUPL68E84A128542 AUZ6Z0C0280902
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01304 - Radio
49-00 - No Communications
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: 71E9DF1B3B525AB68E-4AE8
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11788
Shop #: WSC 63351
VCID: 72EBD0173E5461AE77-4B02
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 040786CF14E05F1E55-4B1A
End-------------------------(Elapsed Time: 05:27)--------------------------
