So my 04 USP (1.8T 6MT). when I bought it, I did not know it had a tune on it. Once I re-did the coils/plugs and did some maintenance, I noticed the car is noticeably quicker than my stock A4 1.8T was. I do not have a Boost gauge, so I cannot confirm what PSI it is running, but I know for a fact it is tuned. 02 sensors are also turned off.
I plan on getting it re-tuned, since I am adding a few couple mods, and want some CEL codes removed, and this way I know where the tune is from. But is there anyway to know what kind of tune my ECU currently has? No stickers or anything on the ECU itself in the car. Can VCDS pull anything up?
Lastly, I am looking for a Stage 1+ setup. I have the stock K03, but I do have larger injectors (410cc). I know many people run the TT 386cc's with stock K03, to get all that can be given from a stock K03, as I guess the fuelling cuts out up top with stock 1.8T injectors.
Basically car as follow will be 3" test pipe, stock downpipe, stock resonator delete, and two magnaflow 4" mufflers. Forge 008, stock intercooler, BKR7E's, Stock intake/exhaust manifolds.
What kind of HP gain can be had with K03 from stock 1.8T injectors to 410cc injectors? So far plan is IMMO delete, keeping rear 02 sensor off, P0441 code removed.
Greg @ SSP will be the one doing the tuning.
Thanks in Advance.
