Results 1 to 24 of 24
Thread: brakes
    Veteran Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    brakes
    alright guys so my brakes have about reached the point of no return. i am only looking to replace my rotors and pads because i feel that the stopping power is enough for my stage 1+. no offence to anyone running them but 18zs are pretty useless on a 1.8t unless you have a serious bt... even though they do look incredibly sexy. i was looking at buying a set of adams rotors because they will bolt right up and not terribly priced at 300$ for the front and rear. until i found this deal:
    http://www.ebay.com/itm/FRONT-REAR-4...0AAOSw5dNWr6ly
    Yes i know its fleabay but they seem legit and come on 150$ for some zinc plated drilled and slotted rotors and ceramic pads? how can you go wrong.. just wanted to run this by you guys and see if any of you have had experience with Brakemotive products.
    Jun 08 2008
    Calgary AB Canada
    Skip the drilled rotors unless you want them to crack. Especially for $150 rotors...
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Nov 10 2015
    Sudbury, ON
    Your car a stock 1.8T with stock brakes? If you not looking at spending too much $$, buy a set of 3.0 caliper carriers, get the 3.0 rotors (312mm vs stock 1.8T 288mm on the front), an extra 10mm on the rear) and get yourself a good quality set of rotors, and some nice pads. Make sure your calipers are in good working order. If you need rotors/pads anyways, your not really spending much more $$, and your getting a little more bite.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Jun 21 2015
    LI, NY
    Quote Originally Posted by jesse500 View Post
    Yeah i actually forgot about this option but is it really worth the extra time/money for that extra 30mm of braking power. Also been scowering throught other forums because brakemotive makes kits for a ton of other vehicles. Theres guys on corvette forums using these on Z06s for years with no issues. So i mean maybe these 150$ rotors arent as shit as some might think
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by B6ayfour View Post
    You can garunteed grab some carriers for like $10 each from a part out/local wrecking yard. If you already need rotors, 3.0 vs. 1.8T rotors are not that far of $$ wise. So realistically, the extra 24mm/10mm is less than a $100 to upgrade.
    Jan 08 2010
    '02 S6 avant 01E, '04 A4 1.8tq USP, '06 Scion xA
    SEA, BOS
    Realistically, unless you live in the mountains and use your brakes constantly or are going to start tracking the car, stick with what you have, rotor and caliper-wise. Get decent quality rotors (one of the centric rotors off Rockauto.com work well) and high quality pads (I'm partial to Hawk HPS).
    If you can engage the ABS system on your car, tire, not your brakes, are the weak link in stopping.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    A good set of of oem pads, I use Textar, and quality blanks, I use Zimmerman give good bite and brake feel. They stop my APR K04 fine. Never felt like I was going to lose the car under hard braking.
    That said I'm upgrading to brembos up front and S4 rears. For looks and the extra stopping power. 😝
    Anyway the point is, you can upgrade to bigger brakes, but the stock setup is adequate enough with a good quality set of pads and rotors. You get what you pay for.
    Aug 19 2013
    minnesota
    I just ordered b8 s5 front calipers with carriers, b7 s4 rear calipers with carriers, centric zink drilled rotors, power stop z23 pads, stainless lines, wipers, hood release, trunk popper, mann carbon air filter, mann intake filter for about 700 - 800 bucks.
    I did hps pads, they were dusty on stock rotors and calipers. Maybe they're better on bigger rotor and caliper....? What do we think of the power bleeder?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Feb 12 2008
    Michigan
    I have a set of 3.0 carriers, make an offer and they are yours
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    3.0 carriers with 312mm rotors, Hawk HPS pads and Tyrol Sport brake stiffeners. Significant improvement with minimal expenditure.
    Jun 18 2014
    Long Island, NY
    I'm selling a set of B7 calipers, if interested. Like new condition, and a nice improvement over the B6 setup.
    Nov 10 2015
    Sudbury, ON
    X2. SS lines would be a nice addition along with a brake fluid flush. Tyrol sport sell Brake stiffener kits along with SS lines.
    Jun 21 2015
    LI, NY
    So the 3.0 carriers are the only thing ill need to run the 3.0 rotors? And is there a different pad for the 3.0 rotor?
    Feb 12 2008
    Michigan
    Same caliper and pad you currently have,
    Mar 10 2010
    Makes you wonder why Audi didn't just put the bigger carriers and rotors across the board.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by claudiovagkraft View Post
    It took them until 2005.5 with the B7 which runs an updated B5 S4 setup. Both the 4 and 6 cylinder B7s shared the same setup. They got it right eventually.
    2019 SQ5 Prestige
    Jun 27 2011
    Quote Originally Posted by texasboy21 View Post
    Yep! Funny how from the b6 -> b7 chassis the A4 brakes got significantly larger, but the S4 brakes stayed exactly the same. They clearly realized how inadequate the b6 brakes were...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 12 2008
    Michigan
    Quote Originally Posted by jacobsen View Post
    sounds like you got a deal, where from?
    Aug 19 2013
    minnesota
    Quote Originally Posted by Fast4esT View Post
    rockauto
    Jun 21 2015
    LI, NY
    So wait a second,this got me thinking. If the caliper and the brake pad are the same while running the 3.0 vs 1.8 setup wouldnt the brake contact area be exactly the same even though there is a larger rotor?
    Dec 28 2006
    Western Maryland
    That would be correct. The gains are a result of the larger diameter. Imagine using a one foot breaker bar to loosen a lug nut. Now imagine using a two foot breaker bar to do the same thing. Larger diameter equals more Newton-meters of torque.
    Jun 21 2015
    LI, NY
    I understand that but what im saying is wouldnt the brake pads need to be larger aswell in order to contact/benefit from the larger diameter rotor?
    Dec 28 2006
    Western Maryland
    Certainly more contact would be a benefit but simply increasing the diameter will increase the braking power even though the contact area and pressure remain the same.
    Basic physics. Torque = Force x distance.
    Edit: Keep in mind that in order to use the larger 3.0 rotors you also have to use the 3.0 caliper carriers. The 3.0 carriers move the calipers further out from the centerline.
    Thus the increased D in T = F x D
    Aug 19 2013
    minnesota
    Get b9s5 fronts, b7 s4 rears. Cheap at rockauto.
