Results 1 to 8 of 8
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Question Temp sensor fuse issue?
    Hello, I have a 2004 S4 B6, my temp gauge on my cluster worked one day and the next is not, light is on in the cluster normally, just doesnt move, I bought the temp sensor already (not installed yet) is there a fuse that goes behind the cluster? if so anyone happen to know the fuse number? or relay?
    Sorry if there is another post on this already, still new to this forum.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    So the light behind the coolant gauge stopped working?
    Probably have a dead LED
    Oct 05 2015
    Billings, MT
    The temp gauge does not move anymore, it used to sit at half way when car has been running for a while.
    Aug 31 2011
    Lathrop
    Oh, misunderstood you. The sensor could cause that if it isn't sending any temp information. Also they servo that moves the needle could have failed
    Oct 05 2015
    Billings, MT
    Ok, so go ahead with the sensor change and see if that fixes it first, roger that. if I have to replace a cluster, it is just a plug and play right, since all the normal info is saved in the computer, i can just put a new one in. saw a video on pulling one and replacing.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Terry.Reese View Post
    No not on these cars unfortunately. You will have to have it paired. If it is the cluster, just get a good motor out of another cluster and plug it into yours.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Terry.Reese - get a vagcom if you don't have one already. They are available from Ross-Tech.com and you want the $350 USB-Can one. It is the best investment that you can make for an Audi/VW. With a vagcom you can do an instrument cluster output test and sweep the gauge needles to see if that is the issue should the new ECT sensor not solve the issue.
    Quote Originally Posted by Jake@JHM View Post
    Yep, the immobilizer has to be programmed to the car by a dealer. It sucks because a new instrument cluster is like $1K-$1.2K and then like a hour to two to have the dealer program it.
    Oct 05 2015
    Billings, MT
    Ok, got it, I have a friend who has a vagcom, I will give him a ring. Thank you all for the help.
