Results 1 to 4 of 4
    Mar 04 2010
    Pittsburgh, PA
    Quick question on tire size
    Looking at some used VMRs coming of a GTI. They are 19 x 8.5 running 225/35/19. Any issue with that size on my S3? Also, the tires have a load rating of 88. Is that a problem? Thanks so much.
    2010 S4, Ibis, B&O, Nav. & Sport Differential retired. 2015 s3, Daytona grey with nav and nothing else.
    Apr 27 2010
    West Chester PA
    In ran that same size on the same size wheel on my MK6R. The only "issue" is that its a bit of a stretch and on the S3 you can fit a wider tire.
    Quote Originally Posted by clerkpalmer View Post
    Mar 04 2010
    Pittsburgh, PA
    Quote Originally Posted by JimmyDever View Post
    Thanks. I will run them to the ground and then when it comes time to replace them go with something wider I suppose. Any thoughts on whether the load rating is a big deal?
    Apr 27 2010
    West Chester PA
    It was fine on my MK6R which should be close in weight to the S3. I had no issues at all.
