Results 1 to 7 of 7
    Active Member One Ring Icepick4u's Avatar
    Dec 19 2015
    AR
    Electronic hand break noise
    Hi everyone. I have a 2011 A4B8, when apply the hand brake, make a loud noise, also when disengage, anyone have a clue about this?, to be more precise with the noise, see video
    TIA
    https://m.youtube.com/watch?v=Hj6ByNIZ8z4
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Seems a little nosier than usual, but still engaging and disengaging okay.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Did you just put on new pads?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Dec 19 2015
    AR
    Yea, works perfect, just the noise
    No new pads, i think are in a middle life with regular surface
    Veteran Member Three Rings Scorpio's Avatar
    Apr 15 2009
    Texas
    I've been getting the same noise for the past few month since it go cold outside, not sure if that has anything to due with it. I too have plenty of pad left also. If I press down on the brake pedal a bit more firm then its not as loud. Regardless, its very annoying when I hold/release the brake .
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Brake
    Dec 19 2015
    AR
    Bump !!!
