Results 1 to 22 of 22
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    3G MMI Won't Start (Screen or Button Lights)
    Hey all,
    I feel like I saw some threads on this before but couldn't find them. My 3G MMI w/Nav didn't want to start up this morning. It is completely blank, no sound, and no lights on the buttons. Temps or water aren't an issue in this case. Interestingly, when I hard/force reset it, it comes on with the splash screen and then dies after about 3 seconds.
    I don't know much, but I believe this means it's getting power fine and receiving signals from the buttons just fine. Anyone have any thoughts? (Will scan with Vag-Com when I get home tonight).
    Thanks in advance!
    UPDATE: Problem resolved - bad amplifier, needed exact part number. Replacement fixed the issue.
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Established Member Two Rings jstarr427's Avatar
    Dec 01 2013
    '05 BMW E46 330i ZHP, '91 3000GT VR4
    Newington, CT
    Quote Originally Posted by maga4 View Post
    Hey all,
    Thanks in advance!
    Scan it and post up here, be sure to run the fiber optic test as well.
    Everything in the MMI system is connected on a MOST loop, basically a fiber optic loop. Each control module receives a FO signal and transmits that signal onto the next module in the loop. If one item fails, everything goes down. The loop test will tell you the status of modules both electrically and optically, which can help you to determine where the break is.
    Had this problem on a 06 A6, found the Bluetooth module under the driver's carpet had gotten wet, so maybe I'd start there. Once I replaced that, I had loop integrity up to the control head, which also turned out to be bad. What really helps in diagnosing these is a fiber optic loop back adapter, which allows you to unplug a module and 'loop' the F.O. Signal to the next module.
    Edit: If you have a break in the FO network (which I'm gonna venture a guess that you do, you won't have communication with most of the MMI modules, but I'd double check all the fuses to make sure that it's not just that.
    I will also post up the PN# for the MOST loopback adapter I have, got it at the dealer, think it was like $30 or so. Worth it to be able to troubleshoot these issues.
    Aug 12 2011
    Olathe, Kansas
    Quote Originally Posted by jstarr427 View Post
    Great, will do tonight. I can run the test without the adapter, correct? Our good friends at the local dealership want $155 plus a few hours to diagnose it, so definitely worth a try. Question: do I have to pull everything out to use the adapter, or just the glove box?
    Dec 01 2013
    Newington, CT
    you can scan it without the adapter, sure. however, In my case with the 06, a bad Bluetooth module was causing the whole loop to show 'ERROR' on electrical and optical tests. the loopback adapter allows you to take a single component out of the system. Sticking with my example, if all you had was a bad Bluetooth module, you'd simply unplug the Bluetooth module electrically, unplug the fiber optic cables and install the loop back adapter in place of the module (I'm talking Fiber Optic ONLY here). What that does is simply lets the optical signals pass through without issue. actually if you look in your trunk on the driver's side, unless you have ALL options, you may see one or more loopback adapter plugged into the Fiber optics from the factory!
    hopefully that makes sense! I'll post up with the PN for the adaptor in a little while, finally outta work!
    Aug 12 2011
    Olathe, Kansas
    Thanks again! Please see below for the scan and a both of the Optical Bus Scans (Normal and 3dB). I'll have to look in the trunk for the loop back and see if there is one there, although, I'm not entirely sure what it looks like ha.
    (The engine code is for a MIL due to either a bad seal or EVAP that goes off every once and a while).
    When it was running through, the Nav screen kicked on for a brief moment with the "Initializing Navigation" message. Other than that, the only thing I can get is the splash screen when I hard reset it). Really appreciate any help...thanks!
    Thursday,11,February,2016,17:41:22:50461
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    www.Ross-Tech.com
    VIN: WAUKGAFB9AN049136 License Plate: 02 11 2016
    Mileage: 76740km-47684mi Repair Order:
    Chassis Type: FB (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 3C 42 46 47 4C 4F 52 53
    55 56 5F 62 6C 72
    VIN: WAUKGAFB9AN049136 Mileage: 76740km-47684miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CCA) Labels: None
    Part No SW: 4F1 910 551 D HW: 4F1 907 551
    Component: 3.0l V6 TFSI 0020
    Revision: --H06--- Serial number:
    Coding: 0105000A190F0120
    Shop #: WSC 02325 785 00200
    VCID: 244DF085E71EE21E35-8070
    1 Fault Found:
    001110 - EVAP System
    P0456 - 000 - Very Small Leak Detected - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 4
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 75214 km
    Time Indication: 0
    Date: 2016.01.15
    Time: 06:02:42
    Freeze Frame:
    Lambda: -3.0 %
    Temperature: 7.5°C
    Temperature: 66.0°C
    Speed: 40.0 km/h
    Time: 332.8 s
    CAT Temp.: 430°C
    Readiness: 0000 0000
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0139123
    Shop #: WSC 02335 785 00200
    VCID: 336F03D952F075A6BC-8066
    Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    No fault code found.
    Address 0E: Media Player 1
    Cannot be reached
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 N HW: 4F0 907 468 G
    Component: GW-BEM 5CAN-M H06 0035
    Revision: MB200030 Serial number: 3000M09B24010D
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 3A712EFDB59A84EE7F-806E
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    1 Fault Found:
    00384 - Optical Databus
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 76683 km
    Time Indication: 0
    Date: 2016.02.11
    Time: 05:52:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 11.60 V
    Count: 11
    Bin. Bits: 00000
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H29 0250
    Revision: 02500029 Serial number: 01247005700000
    Coding: 4618269
    VCID: 356B3DC15C846B9692-8060
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Address 47: Sound System
    Cannot be reached
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 C
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000539953
    Coding: 0002014
    Shop #: WSC 02145 785 00200
    VCID: 5EB9826D89F288CE23-800A
    Address 56: Radio
    Cannot be reached
    Address 5F: Information Electr.
    Cannot be reached
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
    Component: J772__Rearview 0030
    Revision: --H03--- Serial number: 525PA8-J9Y22V2
    Coding: 1000304
    VCID: 2143F991F80CF7365E-8074
    End-------------------------(Elapsed Time: 02:54)--------------------------
    Thursday,11,February,2016,17:44:32:50461
    www.Ross-Tech.com
    VIN: License Plate: 02 11 2016 OBSCAN
    Control Module Part Number: 4F0 907 468 N
    Component and/or Version: GW-BEM 5CAN-M H06 0035
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK ERROR
    5F-Information Electr.(High/D3)OK ERROR
    0E-Media Player 1 OK ERROR
    47-Sound System OK ERROR
    56-Radio OK OK
    Thursday,11,February,2016,17:46:19:50461
    www.Ross-Tech.com
    VIN: License Plate: 02 11 2016 OB3DB
    Optical Bus Diagnostic : 3dB Attenuation
    0E-Media Player 1 OK OK
    56-Radio OK OK
    Dec 01 2013
    Newington, CT
    Interesting, looks like 3G MMI has a different control head address than 2G. The MMI control head on pre facelift cars is 07.
    Anyway, from your scan I'm not surprised you have no communication with the modules listed. When the MOST bus goes down they control modules don't communicate. Everything passes the electrical test so that's good. The fact that you see the MMI logo and then the system shuts down should mean that the control module for the whole thing isn't toasted (I have seen them just go bad). What you need to do now is pretty simple although tedious. gotta access each of the modules that read ERROR and isolate them from the fiber optic loop with this bad boy https://www.ecstuning.com/b-genuine-...tor/4e0973802/ Part number is 4E0 973 802. I'd start by accessing the stuff in the trunk, its easiest to get to. Unplug just the fiber optic portion (connectors with 2 black ribbed cables) one at a time, plug the loop back adapter into the lead you just unplugged, and run the fiber optic test again, and see what happens. if you suddenly see 'OK' for all the other modules, there's your culprit!
    Aug 12 2011
    Olathe, Kansas
    ^^^^ That's great, I appreciate it! I will swing by the dealer and pick it up tomorrow as it looks like they have that part in stock. Dumb question: if some of the modules are in the trunk, where are the others? Do I have to pull the glove box or unit? Hopefully it's just the satellite radio so I can cap that off since I don't use it, but not sure that's my luck!
    Thank you again!
    Dec 01 2013
    Newington, CT
    You've got the sound system/amp in the trunk along with the nav unit, the Bluetooth/Phone (if you have it) is under the driver's seat. The CD changer and AMI (if you have one again) are easy to access, just drop the glove box. You don't have to pull the units out of the glove box, the connectors are all accessible simply by dropping the glove box (6-7 8mm little bolts IIRC). The MMI control unit is also under there, you should see it by where the FO cables go. I do not know where the satellite module is, actually I'm not sure if it's on the fiber optic network at all. Basically unplug one at a time and put the loopback adapter in its place, run test, see what happens!
    It sucks that it's trial and error, but that's the way it works. It's the same on Saab, BMW, Mercedes, etc. I've only dealt with optical networks in Saab's and Audi so far.
    Good luck, glad to be of help!
    Dec 16 2014
    Maga4-
    I'm having a similar problem, and I have some of the same fault codes. My mmi was working, but no audio from any source. Now my mmi is randomly turning off.
    Have made any progress?
    Good luck
    Aug 12 2011
    Olathe, Kansas
    Quote Originally Posted by jasonscott77 View Post
    Maga4-
    Good luck
    Jason - I'll let you know today...thanks to jsarr427's help, I think I have it narrowed down to BT or the Radio module.
    Your's sounds a bit different in that the MMI comes on...I wonder if it could be a bad amp? Do you have the Bose system? Unfortunately, I'm not sure how to test for the amp being at fault. Good luck!
    Aug 12 2011
    Olathe, Kansas
    Well, it turns out it was the amp in my car. $1500 for the amp ($1100 cost), plus who knows how much they will charge to install/code.
    Anyone done any aftermarket amps with the Bose system? Anyone have any thoughts or ideas?
    Dec 16 2014
    Did that diagnosis come from a dealer? Or were you able to narrow it down yourself using the optical bus diagnosis?
    I see you mentioned $1500 for amp ($1100 cost), is the dealer charging you $1500? If our amps are the same part no 4F0035223P , I found it on Jim Ellis Audi parts for $1122. I think I saw a used one on eBay for $600. But I have no idea if others have had any luck with used amps. I also saw a few eBay sellers offering repair service in the $350 range. Again, maybe you can find someone who's had some experience with one of those services.
    Best of luck to you. I'd love to hear what you decide on.
    Aug 12 2011
    Olathe, Kansas
    Jason, I ended up taking it to the dealer, and they "100% confirmed" that it was the amp. They were pricing it at $1500 (with cost to them about $1100) and claim there is only three in the country. I'm not entirely sure that is the case, as - to your point - there are some listed at Jim Ellis and GenuineAudiParts.
    I ended up ordering a used one from eBay ending in "G" but it should work fine.
    Here's the interesting part now - the battery won't hold a charge, and a trickle charger won't keep it charged. I had my battery tested and recharged, and it was testing at 900 cold cranking amps (rated new at 850A). I think that the faulty amp is putting a drain on the battery, but can't confirm that.
    I have it hooked up to a more powerful tender/charger and hope that it can keep enough juice in there to let me jump it once more when the amp arrives. It was completely dead the other day after sitting for about 11 hours (and driven for 45 minutes after a jump before) and wouldn't jump. That's when I took the battery to Advanced to get it tested and charged. I went in to buy a new battery but the guy suggested recharging and testing first, and said it looks "at least as good as new". I have another car I can use for now, but the whole thing is sort of frustrating.
    My favorite part was that it was dead when I picked it up at the dealer after they did the diagnosis and had to have it jumped there!
    Good luck - I will keep you posted on the condition of the amp and (hopefully) verify that everything is working once it's in. It shouldn't be later than next Wednesday.
    Dec 16 2014
    Thanks for the update. I've read about failed amps causing all kinds of problems including battery drain. I completely understand your frustration- I feel like I've been reading about this stuff until my eyes bleed. I can't keep all the info straight anymore. Let's get this amp business out of the way so we can get back to enjoying our cars.
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    http://www.ebay.com/itm/05-2005-Audi...JWu~dZ&vxp=mtr
    The last letter in the part numbers is typically a revision number. So this should work in your car. Make sure they at least look similar before ordering though.
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Dec 16 2014
    maga4-
    Did you have a chance to get your replacement amp installed? Of the used amps I've found online, the "G" letter revisions seem to be quite a bit cheaper than the "P" lettered versions. And I've only found 2 of the "P" variety.
    I hope it's working out for you.
    Aug 12 2011
    Olathe, Kansas
    maga4-
    Jason - apologies for not updating. I had ordered a "G" version hoping it would work, and it turns out the "G" revision is for 2G MMI and the "P" is for 3G MMI, so no luck on that. I ordered a new "P" from Audi Exchange in IL as that was the closest one. The ones I found on eBay (other than the guy selling the speakers too) were all about $1100. The IL dealer sold it to me for $1200 shipped.
    So all in, I'll be $168 * 3 for labor, plus $1200 for the amp. I suppose it's at least new, so there is a warranty. The "G" revision I bought has a return policy, so only be out on shipping for that.
    I also called Bose to ask about repair and they said they hadn't had any 2010 (3G MMI) in yet. From what I gathered, IF they would repair it, it would only be a couple hundred dollars. I'm kind of regretting not taking my original one to a repair shop around here to see if I could get it fixed first.
    As a FYI, unplugging the amp stopped my battery drain, so at least I can drive it now!
    If all goes well, I should have the new one installed tomorrow.
    There are two other Audi dealers who have a new, sealed amp that I can get the names tomorrow (written down at work) if that helps. For 1/2 the price, I'm thinking the guy with the speakers on eBay may not be a bad deal, but frankly, I was tired of dealing with this.
    You making any progress? I'll update tomorrow...
    Dec 16 2014
    That's a bummer about the G amps, clearly there is some confusion as all the parts websites claim they work for 06-11 model years. It was possible to have a 10 or 11 A6 w/ Bose and 2G MMI? I suppose I'll be clicking "buy it now" on the amp/speaker package on eBay tonight. And thanks again for the thorough updates, you saved me from buying the wrong amp. That kind of information is what makes this forum so great. Once I get everything installed, I'll update this thread and mine. Hopefully it helps someone in the future.
    Best,
    J
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    wow, good to know. I though all the parts were interchangeable, but the revision number was just how new it was. TIL.
    2005 BMW K1200S
    Aug 12 2011
    Olathe, Kansas
    ^^^ Yeah, that was my impression. I'm pretty sure it's some sort of software code. The MMI turned on fully with the "G" one, but didn't play any sound. Probably just Audi doing Audi things I suppose ha.
    For reference, here is the receipt from LKQ. I was tricked by the "AUDI A6 2010" and the "07 - 13 Audi A6 OEM Bose Amplifier" into thinking it would work in my 2010 A6!
    https://flic.kr/p/EkuZGa
    Getting the new one put in today and will confirm (hopefully) that everything is all good this afternoon.
    EDIT - Flickr changed so unable to embed the pic at this time.
    Aug 12 2011
    Olathe, Kansas
    Update: The new "P" amp seemed to fix the problem and we are back up and running. Ended up a total of $1200 for the amp plus $168x3 ($414) for labor for those who are interested.
    Hopefully it's good to go for a while!
    Dec 16 2014
    Glad it solved your problem, and everything is working again.
