Results 1 to 26 of 26
    Established Member Two Rings fharper's Avatar
    Jan 23 2016
    Brooklyn, New York
    Help Picking A Engine
    My search for an Audi has lead me to the B6 because all of the B5 i was finding the was in good condition had one of two problems either they were already modded or the asking price was to high and for the price they were aking i could get a B6.
    Now on to what I need help with engine wise I know there are count less things that could be done to the 2.0t but have been leaning to the 3.0 i was wondering options are out there for the engine power wise.
    if you think the 2.0 is better can you tell me why
    thanks in advance
    Aug 19 2013
    minnesota
    There is a 3.slow tune for the 3.0 but the 2.0t can make more power by far, it's a newer design and more powerful improvement on the 1.8t. If you were to pick a motor for your b6 I might say the v8, no turbo to worry about. Find a 2.0 TDI and you'll be the whiff of every nostril. The 2.7t isn't budget friendly, I did just find a source for k04's for $725 however. But that going to be a pricey build hole. Fun though, thats no lie. I rock an apr stage 2 1.8tqm, it's my audi on a budget. Good time to go b6 I spoze, lots of cheap upgrades out there. 18z brakes, garret turbos, intakes and exhaust, injectors, programming, it's all gonna cost ya something. Word of caution, always shop around, you can find good deals, fix things right the first time or you will revisit them on the audi. You wont find a better car community, theres a fist full of dudes carrying many of us sometimes.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    If you can find a 2.7, that could be an option as well. Somewhere in this forum is a DIY that sends to pretty well cover in detail everything you'll need for the swap. I found one local to me for $500, complete, just need to collect all of the parts to make the swap. I would have grabbed it in a heartbeat if not for the other things I need to get first (like a control arm kit).
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    Jan 23 2016
    Brooklyn, New York
    Quote Originally Posted by jacobsen View Post
    Thanks for you input and i'm planing on this to be a long term build so I will save and geet the right parts the 1st time
    Nov 10 2015
    Sudbury, ON
    Find yourself a Nice 04/05 A4 Quattro, 1.8T Auto or stick, your choice. I've had both, an stick is alot more fun.
    A few simple mods, can make it alot more fun to drive, much quicker, and still perfectly reliable.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Aug 19 2013
    minnesota
    Get a 6 speed
    Jan 23 2016
    Brooklyn, New York
    One thing for sure its going to be 6speed
    Aug 26 2005
    Are you asking about OE engines or any engine that will fit into a B6 A4? In Europe and RTW, Audi has a lot of different engines engineered to fit into the B6. Anything from a 1.4l, and 2.0l TFSI gas engines, the new 1.8l TFSI I4 and 3.0l NA and the supercharged 3.0l DI gas engine, several 2.0l I4 TDIs, several 2.7l and 3.0l V6 TDIs and the 4.3l V8 NA DI Gasoline engine. There are also other engines I have not mentioned here.
    If your are interested in only the two engines available to the NA market, the 1.8T turbocharged I4 and the 3.0l NA V6, both port fuel injection, each engine has it's merits and drawbacks.
    The 1.8T is an Audi design originally, and eventually used in VW group vehicles from Audi, VW, SEAT, and Skoda, as well as for industrial and marine applications. The 1.8T is a multiple time 1st place "Wards Best Engines" winner. This engine is amazingly flexible, reliable and fuel efficient while providing unusually good performance. The 1.8T is a very stong engine structurally, and can develope more than 600 HP with enough boost and the correct fuel and ignition timing settings. The 1.8T was developed from the EA113 5 cylinder I5 engines that where produced in the late 70's and 80's, mainly by the development of the ground breaking 5 valve configuration. The newer 1.8T uses continuous intake cam timing adjustment with the exhaust cam timing fixed to the crankshaft position.
    The 3.0l V6 engine is a more recently designed engine that has an aluminum block and heads. This engine is designed along the same lines as the 2.7T and 2.8l V6 gasoline engines with a different bore and stroke and the 5 valve heads with intake and exhaust cam timing adjustment. The 3.0l V6 is not known to be a very sturdy engine due to the aluminum block without iron or steel cylinder liners. Performance increases are limited due to natural aspiration and knock combustion onset limits to compression ratio and ignition timing tuning. There is a supercharger kit available for the 3.0l V6 with a poor record of reliability and problematic performance increases.
    Vorsprung durch Technik
    Jan 23 2016
    Brooklyn, New York
    Thank you for the very detailed response help make the choice a little easier
    Jun 18 2014
    Long Island, NY
    I have a full 2.7t swap for sale in the FS section. Engine, harness, ecu, intercoolers, etc.
    And I'm right on LI!
    Established Member Two Rings Digitaldub's Avatar
    Apr 29 2010
    Toronto, Ontario, Canada
    Is your source able to do the K04-015 for $725?
    Thanks,
    Aug 19 2013
    minnesota
    Quote Originally Posted by Digitaldub View Post
    Thanks,
    Diesel performance inc, minnesota.
    Jan 23 2016
    Brooklyn, New York
    Veteran Member Four Rings idotavant's Avatar
    Jan 20 2016
    wv
    what are your engine needs/wants? for what purpose is the car? these are related questions. the community needs to know what you want the engine to do to give an opinion on an engine to suit you.
    05 Allroad 4.2 ao3 swap; jhm v3 kit
    06 Dakota 4x4 long travel v8 6spd
    03 Tuono 1000
    04 MB c240 4motion wagon (gf’s)
    02 a4 avant 3.0 tip (defunct; part-out or sale)
    Jun 27 2011
    Quote Originally Posted by fharper View Post
    Nope. That looks haggard...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 23 2016
    Brooklyn, New York
    Quote Originally Posted by idotavant View Post
    I plan to build the to about 450-5 whp over the next couple of years this is going to be a long slow project I want to make sure I do everything right the 1st time
    Sent from my SM-N920T using Tapatalk
    Jan 23 2016
    Brooklyn, New York
    That's what I was thinking
    Jun 08 2008
    Calgary AB Canada
    And you're set on a B6? If so I'd say start with a 3.0 6 speed car and do a 2.7t swap. 450whp out of a 1.8t will be difficult and no fun to daily drive.
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Mar 01 2013
    Denmark
    2JZGTE
    Jun 27 2011
    Quote Originally Posted by onceover View Post
    This.
    -CP
    2017 Q7 3.0t
    Jan 23 2016
    Brooklyn, New York
    I found a 04 with 216000 miles on it for 2,500 taking a look later 1.8t
    Jan 23 2016
    Brooklyn, New York
    Look what I got today
    Aug 19 2013
    minnesota
    Good price, any problems? Now for that 2.7t gt28 build...!
    Jan 23 2016
    Brooklyn, New York
    The CEL was on for misfire on coil B but i cleared the code and waiting for it to come back on hoping it was just a fluke
    Jun 08 2008
    Calgary AB Canada
    1.8t? You said you wanted to start the build right. That would have been a 3.0.
    Stock. For now...
    Jan 23 2016
    Brooklyn, New York
    yes it is 1.8t
    the 3.0 i was looking had a lot going with it so it turned me off from that car then this guy with the 1.8t made it to hard for me to say no
