Results 1 to 22 of 22
    Aug 06 2012
    san diego
    Threw a fault code today: Cam Adjustment Actuator B; Cylinder 3-Implausible signal
    How concerned should i be?
    One thing that i noticed different was that the car no longer had the dsg fart after this MIL
    Its going to the dealer in the morning for its first oil change- so i will def. have them take a look. (probably won't tell them that I already know what the code is)
    I was bummed to see this light... Anyone else get this one?
    only 4,400mi and bone stock...
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    You need an APR tune to sort that out
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Aug 06 2012
    san diego
    Quote Originally Posted by roadrunner_oz View Post
    APR sucks
    Nov 13 2009
    the OC, SOCAL
    lol.
    you do know he was being sarcastic because what has happen recently?
    Aug 06 2012
    san diego
    no what happened? something about his apr tune not working out anymore?
    Mar 30 2015
    Australia
    Quote Originally Posted by markn1689 View Post
    I have APR ECU tune and no error codes. You really need to get APR
    Jun 29 2015
    Highland Park, CA
    The day he gets an APR tune is the day hell freezes over.
    Mar 30 2015
    Australia
    Quote Originally Posted by gp813 View Post
    It would fix his error though ;)
    Oct 30 2012
    Arizona
    APR Rules....even though I run GIAC cause its better.
    Aug 06 2012
    san diego
    how would an APR tune fix my fault code?
    what the hell are you smoking?
    Sep 13 2015
    Hell City, Az.
    I get random codes, whose frequency is just 1, meaning it has happened only once and then the computer was fine.
    I say, erase codes and keep driving, or if already going to stealership, then have them check it. But probably will just erase the codes for you. :)
    Senior Member Two Rings soulflyer's Avatar
    Apr 06 2015
    Ottawa, Canada
    Cylinder 3... hmmm keeps popping up, one hardly hears from cylinder 1,2 or 4...
    http://forums.vwvortex.com/showthrea...0A-P03AF-P0726
    check post 19 too...
    and yes I have always some fault codes in the system. I report them every time I go in and they just erase them...
    2018 S3 Technik, Ara blue
    SOLD 2015 S3 Technik, Sepang blue
    I have VCDS, will do scans and coding for beer in the Ottawa ON, area. PM me.
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    See here...
    I had a bad actuator on cylinder 3
    From what I can ascertain, as long as the lights (if any) are not going blinky blinky with chimes or alerts or the cluster lighting up light a Christmas tree, you should be good to drive it around hopefully to the dealer but IMHO I would not ignore the errors/alerts.
    Mar 30 2015
    Australia
    Why so serious?
    If there is no EPC dash warning light then not severe or cause for concern unless it keeps coming up. Clear it and check again later. The error is basically stating that it expected a signal from the sensor and never got one at the particular time.
    Aug 06 2012
    san diego
    the dealer actually replaced physical parts to address this issue. i will update with part numbers and more details when i pick up the car either late tonight or tomorrow.
    Aug 06 2012
    san diego
    They replaced part# 06E-103-697-M
    To test, they swapped cylinder 3 shift actuator with another cylinder and the error code followed.
    No more MIL. Dealer scuffed my car and I had to use rubbing compound to get the scuff out. Not really happy with Hoen Audi
    Apr 11 2012
    That part sounds notorious for failures:
    Quote Originally Posted by ecs
    Valve that controls cam adjustment. There are numerous parts on your vehicle that are known to fail and one of them is the N205 Valve that controls cam adjustment. This part has an extremely high failure rate, so if your car is throwing you a code for the N205 valve, you might want to replace this part to maintain engine health.
    Jul 27 2015
    Ontario
    Chiming in....
    @ markn1689
    They performed the exact same procedure, swapped out the sensor on cylinder 1with the the faulty sensor originally on cylinder 3 and the error followed.
    @ will13k7
    Its beginning to sound like a particular batch of faulty sensors......but..........on cylinder 3?
    Another question to ask the dealership which I doubt will provide answers!
    Aug 06 2012
    san diego
    it must be easy to swap this part out. a write up would be nice
    Jul 27 2015
    Ontario
    Quote Originally Posted by bakedcorn View Post
    Chiming in....
    @ markn1689
    @ will13k7
    Resurrecting this post from the dead!
    Well apparently I got a second CEL or MIL on the dashboard last week Friday, May 4th, 2018.
    Started up the car after work and she ran rough for about half a minute and then settled into the usual smooth idle.
    I hooked up a cheap OBDII scanner and reported a possible MAF issue however upon taking into the dealer, they told me it was Camshaft actuator on cylinder 1 this time?!??!
    I wanted to tell them that I got a totally different error with my OBDII scanner but I didn't want to tell them that I was hooked into the system in case they would flag it. They threw me into a courtesy vehicle and sent me on my way.
    My confidence in this car is at an all time low given that I have less that 37K km's on her and have had two sensors within the same family crap out on me.
    Anyone else with said issue with these sensors?
    Thanks
    Senior Member Two Rings zimzima05's Avatar
    Dec 26 2006
    k7 Gixxer 750
    Any update on this ?
    - - - Updated - - -
    Jul 27 2015
    Ontario
    The sensor was replaced
