Results 1 to 4 of 4
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Milltek Question
    Gents there's a ton of options on the milltek site. That said, Have i seen 2 non res models that are both not the valvesonic system? I believe I've seen non res with and without the rear silencers and both as the non valvesonic system. Am I right or is there only a non res/ non valve (no rear silencers) and non res/ valve (with rear silencers)?
    '13 S6
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    The systems are completely modular you can use any bit of it with the other components. My setup is the cat bypass pipes to non res down pipes to center silencer to rear non valved silencers and it sounds freaking amazing!
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Milltek Question
    I understand anything can be customized but I wasn't aware it came with rear silencers without valve and non res d/p's. I bet the cat bypass really wakes this and the neighbors up. Thank you.
    '13 S6
    Nov 19 2005
    Central IL
    Quote Originally Posted by turbello18 View Post
    I didn't customize anything I ordered straight off of Milltek part numbers and it was all direct bolt on. The only thing you can't do is run a resonated downpipe with the cat bypass pipe. You can but you'd have to do some customization to the flanges in order for them to mate properly. You can literally order each section separately rather than an entire system. By the way the non valve sonic rear mufflers are actually quieter than the valved units at cruising speed but when you get on throttle they wale beautifully.
