Results 1 to 10 of 10
    Active Member Two Rings SpooledUpS4's Avatar
    Dec 23 2015
    Algonquin, IL
    Vacuum Line Kink
    Hey all, I bought myself a podi steering wheel pod and a boost gauge to go along with it. The install seemed to go pretty smooth but the gauge won't read any vacuum or boost. I tee'd it at the fuel pressure regulator braided line, where ecs and awe had said, and I drilled a hole through the ecu box for the line to run through. I got the line all the way to the steering wheel, from the t to the ecu there aren't any kinks. As far as I can tell, there aren't any near the fuse box/ steering column. Do you think when I attached the actual podi steering pod, which goes over the oem steering wheel column cover, it might of kinked the vacuum line tubing from where it attaches on the back? It's pretty hard plastic so I'd imagine it could put pressure on the line and taper it off. I'm taking the gauge out on friday when I have some time and hooking it up to an air compressor to make sure the gauge itself is not defective. If any of you have used the podi setup, did you feed the boost line through the same way as I did? Do you see where it could kink? I appreciate you taking the time to read this. I'd apprecaite any advice you guys have to offer.
    -Vishwa
    Jul 04 2012
    Woodbridge, VA
    Yes, I think that could be the problem OR its leaking. pressure test from the connection on the T.
    Dec 23 2015
    Algonquin, IL
    If it were leaking, wouldn't the car drive a lot worse? I've driven it over the last coupe days and it seems fine.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by SpooledUpS4 View Post
    Yes. A large enough leak to where it's not working would. Pressure test it for functionality.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Disconnect the vacuum line from the gauge, start your engine and using your thumb to see if you feel any vacuum at the end of the hose. You should be able to hear a hiss if there is vacuum being pulled from the hose.
    If there is no vacuum then remove the column pod and check again. If there is still no vacuum with the pod removed then you have a pinch upstream or tapped the wrong location for the air sample.
    If you do detect vacuum then check the inlet to the gauge to make sure it is not clogged with some debris.
    If you need further assistance give me a call at 800-861-7634.
    Dec 23 2015
    Algonquin, IL
    I pulled the t off today and pressure tested it, the gauge is functional and the needle moves. But while pulling the t off the braided hose from the fuel pressure regulator snapped. I saw that it goes directly near the egt sensor, by the intake manifold. Is this true? It only snapped off like a foot, so there should still be quite a bit of braided hose correct? I'm going to buy a 3mm vacuum line from the auto store near me, just want ask where the line goes into. Anyone know where it goes?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The fpr hose runs from a nipple on the back center of the in mani to the fpr.
    Anywhere on this line is fine.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 06 2008
    Canadia
    That braided hose has probably had its day and could be a likeley cause of your problems
    the B5 S4 is like the mafia... there is only one way out!
    Nov 16 2010
    WetSide, WA
    Yup, a foot or two of typeR 3mm (1/8") silicone from the furious isle at Vatozone should fix it right up
    Dec 23 2015
    Algonquin, IL
    Got everything working, went to autozone and got 2 feet of 3mm vacuum tubing, shout out to the guy who gave it to me for free, and connected everything back up. I guess the FPR hose was the problem all along.
