    Mar 04 2010
    Pittsburgh, PA
    Navigation stuck on Los Angeles
    Tonight my navigation stopped working. Shows downtown Los Angeles. I live in Pittsburgh. I tried resetting the mmi but no luck. The map doesn't even move. Seems like the signal isn't working and it's defaulting there. Any thoughts as to how to fix other than a dealer trip would be appreciated.
    2010 S4, Ibis, B&O, Nav. & Sport Differential retired. 2015 s3, Daytona grey with nav and nothing else.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    try disconnecting the negative terminal of the battery for 10 minutes and connect it back this will do a system reset and might help you fix the issue. good luck
    Mar 04 2010
    Pittsburgh, PA
    Restarted after an hour and signal is back. Problem solved.
    Veteran Member Three Rings ryan_sn's Avatar
    Jun 01 2008
    2016 Audi S3 Daytona Grey
    Ontario, Canada
    Move to LA, problem solved.
    LOL jk glad to hear it's fixed
    2007 Audi A4 2.0TQ Quartz Grey
    2012 A4 Quattro 2.0TQ Monsoon Grey
    Present:
    Future:
    2023 BMW M3 Competition xDrive - Toronto Red
    Mar 04 2010
    Pittsburgh, PA
    True although the stuck location looked a little sketchy ...
