Results 1 to 8 of 8
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Angry Boost cut at 5500RPM
    Why does my boost cut off completely at 5500 Rpm like it holds a solid 22 and after 5500 Rpm then the gauge just drops to 0PSI
    Is this like a safety feature so i do not over boost
    HELP PLEASE!
    Mar 04 2015
    Champaign, Illinois
    Quote Originally Posted by 123lilc View Post
    HELP PLEASE!
    Any One?
    Apr 07 2011
    Have you scanned for codes? Even with no Check Engine Light there can still be codes stored.
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    k03/k04 turbo?
    Mar 04 2015
    Champaign, Illinois
    gtx turbo and yes no codes
    i think it might be my revo tune
    does a tune do this for safety because it will hit 29psi and then hold 25psi and then at 5500rpm it goes to 6psi
    any thoughts?
    (the reason why in the first post it says 22 is because that was a low boost tune so i turned it to full boost to see if that would fix it and that's why the numbers in this post are different)
    Apr 07 2011
    Should probably contact Revo and ask them if that's a feature in their software. Also, if you have access to VCDS, take some logs with requested vs actual boost.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You definitely need to log your actual versus requested boost. This will tell you if the boost cut is being controlled by the ECM (limp mode) or if its a mechanical problem.
    Mar 22 2010
    East Coast US
    collapsing tip
