Results 1 to 21 of 21
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Neuspeed Intercooler
    Looks like this is bottom mounted instead of sandwich mounted between radiators.
    Fits Mk7 GolfR. Not sure if it does on the S3.
    Kool that it's bottom mounted for an easier install.
    I'm guessing the OEM intercooler is left in place?
    http://www.neuspeed.com/481045-fmic-mk7-golf-r.html
    -cW
    2023 X3 M40i Alpine White
    Active Member Two Rings Workflow's Avatar
    Jan 19 2016
    1967 pan up
    Southern Cal
    I ran the Nuespeed front mount on my GLI. Being that it's front mount, the original intercooler stays in place and is simply capped. Easy instal and if you have to make a trip to the dealer, easy enough to pull it and plug the OEM cooler hoses back on. Pretty convenient and a quality piece.
    Sep 13 2015
    Hell City, Az.
    I like it.
    I think the stock one would stay in place, you just reroute the hoses.
    I wouldn't take the stock one out. It would've been nice if its performance was compared against other ICs.
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    This intercooler setup is only for the Golf R not for the S3 even though they share the same engine. Just a heads up
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by ModdedEuros View Post
    That's too bad. I have contacted neuspeed to see if this could work for the S3 or if there are plans to make one for the S3.
    I also asked if they had some performance data to share.
    -cW
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Quote Originally Posted by Workflow View Post
    Why would you pull it when you went to the dealer? Also, why would you leave the stock one in there if it's simply capped off? Lot of extra weight to be needlessly pushing around.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Looks like the oem intercooler is a PITA to replace. Requires 4-5hrs labor. So if a bottom mount option is available it could cut the labor hrs down by a lot. It's extra weight to lug around, but might not be too bad.
    Checkout this install video for a mk7 gti.
    https://m.youtube.com/watch?v=g2abu2DZIO0
    -cW
    Sent from my SM-G900V using Tapatalk
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Response from Neuspeed.
    Looks like they just need to work out the mounting brackets.
    "Thank you for your interest in Neuspeed.
    Our IC brackets are unique to fit the Golf R and we have not been able to check the S3 yet, trying to get a vehicle ASAP.
    Factory IC does not need to be removed, but we are building a delete kit.
    We have not published charts yet, but will be far better than any factory IC upgrade replacement.
    Regards,
    Neuspeed Team"
    -cW
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    I did the install on a 13 Golr R and it is such a PIA we left it on when we traded it in. I also called Nuespeed and got the identical answer as did coolwater.
    Aug 23 2014
    Philadelphia, PA
    The OEM is tricky to get to but really is not that bad if you are use to working on cars. Personally I would not install a FMIC and still leave another OEM IC in place. If purpose of putting down more power you do not want to have unnecessary weight just sitting in there
    Modded Euros
    www.ModdedEuros.com
    Jan 19 2016
    1967 pan up
    Southern Cal
    Quote Originally Posted by phillyquattro View Post
    Not suggesting one would, but for the paranoid, this might be convenient since it's easily done. As to the weight, sure it makes sense to pull the OEM for the sake of "race car". Some find pulling the OEM intercooler is more of a PITA than the weight savings.
    Oct 01 2015
    Karachi, PK
    Forge make twintercooler for Gti/R, which work together with oem intercooler does that not adding extra weight??
    2015 A3 1.8TFSI 7speed S-tronic (FWD)
    Engine mod BMS JB4/ Revo catless DP/aFe dryflo drop-in/stock intake mod/Revo MQB Intercooler/Revo muffler delete/CTS TIP/GFB DV+/034 dog-mount ......VCDS mod visual parking aid, needle sweep & oil temp on DIS
    Aug 23 2014
    Philadelphia, PA
    Quote Originally Posted by slick99 View Post
    Correct. Not a fan of the twintercooler
    Modded Euros
    www.ModdedEuros.com
    Oct 01 2015
    Karachi, PK
    any news from Neuspeed?
    Neuspeed has my car to confirm fitment and install...so I'm guessing they should be posting something soon.
    His: #samoas3 | 2016 S3 | P+ | Audi Exclusive Samoa Orange | GIAC Stage 2 + TCU | Neuspeed | 034Motorsport | CTS Turbo | HG-Motorsport | Neuspeed RSe102 19x9 et40 *138.8 MPH Half-Mile*
    Hers: #lavasq5 | 2014 SQ5 | P+ | Lava Gray Pearl | AWE/GIAC Stage 2 | KW | SPC | 034Motorsport | AWE | RS Grille | 285/30ZR22 on DPE CS5S 22x10 et22/26
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by mmth_ski_bum View Post
    Nice, hopefully it's a good fit. Do they plan to also test capping the oem intercooler?
    -cW
    Senior Member Three Rings DarkSideGTI's Avatar
    Feb 05 2008
    SL,UT
    If the Neuspeed IC is anything like the one for the MKVI then it is pretty terrible. My buddy over at Integrated Engineering tested his IC against the Neuspeed and blew it out of the water. I will be waiting for the IE one.
    2017 Avalanche Raptor
    2015 Monsoon Grey S3
    -cW
    Fitment was a no go...the ducting on the S3 for the DSG heat exchanger and oil cooler is larger than the Golf R and A3. It interferes with the end tanks and silicone hoses.
    Unless someone comes out with a narrower/taller front mount, you're stuck doing the OEM replacement.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Ok good to know. Thanks for doing the test fitting for all of us.
    -cW
    Oct 01 2015
    Karachi, PK
    Thanks for letting us know, so tht mean any fmic wont fit in S3
    Aug 23 2014
    Philadelphia, PA
    You can always make something work. It will just be a matter of how big of a core can you fit in there and how much trimming will be needed. And than as a result are you really doing a intercooler for looks or performance at that point.
    Modded Euros
    www.ModdedEuros.com
