Results 1 to 2 of 2
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Rear ABS Tone Ring inspection
    I have slow speed ABS pulsing (under 20 mph), one pulse per wheel rev.
    I cannot get the rear wheel speed sensor out (rusted in solid). Front left replaced, front right cleaned.
    Since the pulsing is one pulse per wheel rev (and NO ABS code, wheel speed data showing in VAGcom on all 4 channels), could it be a dirty tone ring?
    Is it possible to inspect the tone ring of the rear shafts by just removing the axle bolt and push the shaft in, exposing the tone ring (remove rubber boot)?
    Any other suggestions what to check or try to eliminate the annoying low speed ABS pulse?
    Swapped ABS module (on pump) with new one, no change.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Its either cracked ring, dirty ring, messed up sensor, or messed up module. My money is on cracked ring.
