Results 1 to 15 of 15
Thread: Fuel Pump
    Aug 31 2014
    Wake Forest NC
    Fuel Pump
    So my fuel pump has decided to crap out on me and needed some guidance on where to go next. I do plan to eventually go stage III but I am currently stage II with APR tune, downpipes, 3" single exhaust and coil pack conversion. I would rather only do the fuel pump once so what would work well with stage II and be sufficient enough for stage III? Also, should I do the injectors at this time?
    TIA,
    Dan
    2001 Audi S4 Stage 2+/APR Tune/RS4 Clutch/Flywheel/034DP
    Jul 04 2012
    Woodbridge, VA
    You shouldn't do your injectors and drive on it without retuning.
    As for fuel pumps, I've heard Bosch 044 will do you well for stage 3
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Quote Originally Posted by SilverBulletS5 View Post
    TIA,
    Dan
    http://sillyrabbitmotorsport.com/Fue...walbro,450,e85
    i recently did this, check the drop in kit box for the additional $70. so far so good. reasonably priced too
    2008 Ibis RS4....GETing tuned
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    You can get the the walbro 450 pump cheaper online. And re-use your OEM basket with just a few O-rings.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by xalents23 View Post
    That's what I did with my walbro gss340 in my A4. I jammed some AC delco sock on there too
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    ^ my boy runs that pump on his b5, no complaints. no issues.
    Aug 31 2014
    Wake Forest NC
    Quote Originally Posted by axnjaksn View Post
    Thanks dude! I am going this route, how long did it take you to get the pump after you ordered it?
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    Go with Bosch 044 or Walbro 450. Those seem to be the most common. I'm running the Walbro 450 in my stage 3. Ordered the kit from SRM and I can't remember how long it took to arrive; I want to say about a week. It also comes with a bracket so that you can mount it right into the stock basket.
    Aug 06 2008
    Canadia
    Can't go wrong with the 044, tried and true.
    034 said the AEM 0ump they offer is a good replacement for a stock basket, I think they said it's good to stage 3 and that's it (no e85 or k24's) but best to call and confirm that because it was awhile ago I asked them. Currently I have a 044, it increased my fuel economy about 20-30%, don't know why, but I like it.
    the B5 S4 is like the mafia... there is only one way out!
    Established Member Two Rings JaredB5s4's Avatar
    Jan 12 2016
    Kitchener Ontario Canada
    Fuel Pump
    http://www.projectb5.com/product/dea...p-in-fuel-pump hb this one????
    Did any one try this??
    Senior Member Two Rings antisparkplug's Avatar
    Jul 29 2011
    Northeast
    Bosch 044 with 034 basket if you don't want to fab your own up. Tried and true.
    It's also slightly easier to hear operating, which is helpful when you're trying to diagnose any issues. Btw, I bought mine on amazon... solid value.
    B8 A4 Avant - 8AT
    Previous:
    B5 S4 Avant - 6MT - EPL Stage 3
    Aug 06 2008
    Canadia
    Quote Originally Posted by antisparkplug View Post
    How does it sound with the CNC'd basket? I have the Audi v8 basket and it sounds like a tire with a pinhole leak from the outside, no mechanical noises
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Quote Originally Posted by MacDaddy View Post
    I've got the 034 bracket as well - I'm sure it sounds the same, slight hissing noise. Fuel pump sounds like a fuel pump.
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    I run a Stealth 340 but will be going with one of the new brush-less style pumps with a digital controller. It will be the future for big power, big injector e85 builds. Companies that support this platform like SRM already have moved in this directions.
    Jul 29 2011
    Northeast
    Quote Originally Posted by wbrunner23 View Post
    Yeah this is correct. No different sounds with the bracket, but the 044 emits a very soft hissing type noise. I don't have the loudest exhaust, but I can only hear it from idle to maybe 2k rpm.
    B8 A4 Avant - 8AT
    Previous:
