Results 1 to 20 of 20
    Registered Member One Ring JonAth4n's Avatar
    Dec 08 2013
    99.5 A4 1.8TQM written off 04 A4 1.8TQM :(
    Oakville, ON
    Question B5 T3 turbo questions?
    Hey guys! So I'm pretty new to the b5 scene and am wondering if a T3 turbo will have more substantial gains appose to a ko4. Since the Canadian dollar is rough right now I was looking at this, http://www.imageinmotion.com/REV9POW...-Charger--48AR
    Now I know the k04 is a direct bolt on but what about this T3? what will I need in order to make it "bolt on"? Are the flanges the same? Will I need to re-route oil lines? etc. I'm just looking for more power in a daily driver, which is much needed in my case lol. Thanks in advance, cheers
    Chill the f*ck out! I'm here to learn!
    Active Member Two Rings Hascall's Avatar
    Nov 28 2013
    Birmingham, Michigan
    To answer your question, no. To actually install the turbo you will need a different manifold. Beyond that, the possibilities are endless. Oil feed and return lines will most likely need to be changed as well as the intake and down pipe. You will also want to upgrade your intercooler. Not to mention, depending on what turbo you go with, your factory rods are also in question when you get into these larger sized turbos.
    Thats super awesome if you are willing to take a project like this on, but it surely is not for anyone. We do many turbo upgrades here at our shop in Michigan and every customer that upgrades to a K04 is extremely happy with how street-able their car still is while still being able to enjoy plenty of weekend spirited driving
    Dec 05 2007
    I suggest the Frankenturbo. Bolt on like the k04 and may be all you are looking for.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    1. Do some searching
    2. Don't buy junk turbos
    3. Frankenturbo
    Mitch you always be sneaking in like that!
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    Mitch is like the post ninja.
    Dec 05 2007
    An old art, not yet forgotten
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Apparently the Canadian dollar is weak right now. It's like the new roads are bad excuse?
    Dec 10 2013
    Borden, Ontario, Canada
    The excuse? Oil prices. Guys in the states are paying $1.71/gallon for 93.
    You know what we pay for that here? $3.99/gallon. It's so dumb
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    Show me a station with 93 for $1.71 and I'll be there in a second! Where I live it's still 2.49 for 93 although that's still significantly lower than $4.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by pgiuliano98 View Post
    $4 CAD is only $2.87 USD, which goes to show how bad the CAD is right now.
    2000 S4- Working?
    Jun 22 2015
    Livonia, New York
    Ahh I see now.. I forgot to take the conversion into account but $1.71 was still a stretch.
    Active Member Two Rings Rampid's Avatar
    Dec 14 2006
    Chicago IL
    I'll chime in since I just finished a budget T3 build. The minimum you are going to need to see any significant gains will be; manifold, turbo, oil lines, intercooler, downpipe, intake, injectors, wideband gauge and a tune. You should be able to find all of this for under 3k if you are resourceful. With a t3 you probably won't have to replace rods since the boost onset is so gradual. I've been running a .63 T3/T04e at 24psi on stock rods/ fuel pump for over a year now without issues. I might throw an inline fuel pump on this summer just to be safe but Ive been driving the car hard with stock fuel pump, rods and clutch and have yet to run into any issues. My MPG actually improved due to the later boost onset.
    Jul 07 2009
    Socal/IE
    Don't think I've paid under 3bucks here in cali. 91
    I don't really look at gas prices it's a needed thing.
    Feb 02 2016
    Salem, SD
    Premium 91 here is $1.76 right now ;) https://m.gasbuddy.com/touch/?usite=...onDetails_page
    Dec 10 2013
    Here you go:
    http://www.audizine.com/forum/showthread.php?t=681536
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Think I paid 1.73 last fill up, 91 of course. That t3 is basically a gt2860rs. I would buy a used 28 before a revpower.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I would 2nd the used gt28 vs off brand turbo. I got all my stuff new 2nd hand for 900 bucks turbo mani injectors maf fuel pump tip 008 DV. Just have to shop around. 93 oct is 2. 20 here
    Sent from my SM-T560NU using Tapatalk
    SOLD the GOINHAM A4 ---> GT2860 Project
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    ill take the pic on my way home from work...paid 1.49 for regular in the work truck yesterday in mass premium is between 1.69-1.79
    Jun 22 2015
    Livonia, New York
    Well NY is ranked 48th in cheapest gas prices throughout the US so that explains my problem... :/
    Nov 27 2010
    mass
    ah that would be it...which makes no sense considering its next to jersey which is the cheapest.
    As for this turbo question..as people have said, go with the franken turbo or maybe an eliminator.
    youll need a clutch, tune, injectors, intercooler and a downpipe to start. You can reuse oil/water lines but new ones are advised. You can make your own for pretty cheap.
