Results 1 to 9 of 9
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Kill the rattle!!!
    So i am getting sick and tired of all the cabin rattles with subs,and I've searched the forum and found a few culprits but has anyone with aftermarket subs been successful in finding all of the noisemakers and silencing them? It's not that I'm blaring anything with absurd bass, there seems to be a different noise for everything I listen to coming from a different place. Config is a dual 10" ported box rear facing mounted right up to the rear seat backs in the truck. Any input would be awesome before I say to hell with it and rip the subs outl. Thanks guys
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I have stock sound system but I still get rattles from the panel where the sunroof controls are. That seems to be very common and a lot of people open it up and add a piece of foam with double sided tape up there (DIY somewhere). Not sure where else you're getting rattling.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Established Member Two Rings Snowboardguy989's Avatar
    Feb 02 2011
    F350 Dually, Volvo xc90 V8
    OKC
    I cant remember which car show it was but they joked about driving a VAG product after the factory and stating that the engineers would add a rattle to the car if none was found during the test drive
    Sep 02 2008
    Boonies VA
    Where are your worst rattles coming from? I run a 10" sub, albeit in a sealed enclosure and the sub does not produce too many noticeable rattles. I added some deadener behind where it is located though (mine sits in the cubby on the left side of the trunk). Mid bass in the doors do create some rattles, but I think its just stuff in the door pockets rattling. The rattles are definitely worse in the cold though.
    White Wagon
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by naiku View Post
    Its been in the 20s lately but looking at single digits next week and its deff worse in the cold, my main rattles are rear view mirror, around the sunroof, and something behind the back seat
    Sep 02 2008
    Boonies VA
    Try what supple suggested around the sunroof controls, pretty quick and easy way and may cure those rattles. For the ones behind the back seat I would bet it being something on the back deck, try playing some music that causes the rattles and then just putting your hand on various pieces on top of and beneath the rear deck. Hopefully that gets you to the point you can find what is rattling back there and at that point can look into options to stop it rattling.
    White Wagon
    May 11 2013
    Very interested in doing this as well because I am also getting the dreaded rattling from that same location. Having a hard time tracking down a DIY -- found a few for older generations though.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Have you tried country music?
    Seems to have worked in "Mars Attacks".
    Apr 03 2011
    Hong Kong
    2007 A4 B7 2.0T S-Line
    :: Oettinger Front Bumper :: Oettinger Side Skirt :: DTM Rear Bumper :: S4 Door Blades :: Rays Homura 2x7 2014R 19x8.5 :: PSS 235/35R19 :: GRD Chrome Side Mirrors :: Blesk 3000K HID@OEM fogs ::Unitronic Stage 2 :: APR Carbonio Intake :: 034 High Flow Cat :: Miltek Catback :: 034 Catch Can :: CTS Turbo FMIC :: Plasma Direct Ignition Coil :: NGK Iridium IX :: 034 Snub Mount :: 034 Front Swaybar Endlinks :: 034 Rear Swaybar & Endlinks :: ST Suspensions Coilover ::
