Results 1 to 14 of 14
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Who thinks this swap is impossible or a bad idea?
    -Tim
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I mean, it won't be a straight drop in. I would expect quite a bit of custom work.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 13 2007
    Yeah, I'm just deployed, bored, and exploring dumb ideas for my RS4 avant build. That V10 sound and a widebody avant would be awesome.
    -Tim
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I fully encourage this, and suggest a build thread so everyone else can follow along; but hey...it's not my money, so I am just here for the entertainment.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by sandspeed View Post
    Are you thinking of not using the RS4 powerplant?
    The V10 is going to be way more custom fab -- and way more headaches. It'll be bad ass...but it also has a cap -- there's virtually 0 aftermarket support for that engine. If you ever get tired of the stock power, if you run the RS4 V8, there's always supercharging.
    Its completely opinion based, but I prefer the sound of the 8250rpm v8 to the v10.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Mar 13 2007
    Quote Originally Posted by ryanhmusic View Post
    I'm starting with a 3.2 V6 avant, so I need to source a good engine for the swap. This leaves me open to anything really.
    -Tim
    Aug 05 2014
    any consideration on using the 3.0TFSI?
    If you're starting with a 6-speed, there should be little to no fabrication involved, the engine is capable of plenty of power with a tune and pulley -- seems bulletproof.
    With the avant and RS4 hips, it would be a KILLER daily.
    but it won't sound half as good as the v8 or v10....
    May 31 2015
    2017 Mazda CX-5 Touring
    Twin Cities, MN
    I think people here covered it pretty well... Wolf Auto is local to me, they are solid. The V10 is a lot of headache just to be different, not better. In theory starting with a 3.2 sets you up well for a 3.0T swap, but I still haven't seen many people successfully complete the swap. Personally I would just go with the old 2.7T. That swap is known and proven and so is the powertrain. It maybe isn't as special, but a ride in my buddy's Stage 3+ swapped B6 avant sold me. When the 2.0T kicks the bucket in my B7, I want a 2.7T. Hopefully that is awhile out though. That is my suggestion at least if you actually want to drive your car and go fast. If you want to pay shops thousands of dollars for a car that won't get finished, and leads to a partout you get 50% back on, by all means, blaze the trail with a 5.2 swap.
    '06 A4 Avant 2.0TQM S-Line Brilliant Red- | JHM High Flow Cat | Bosal Center exhaust | 034 Snub, motor, & trans mounts | 034 Spherical Front Sway End Links | 034 Street Density Control Arms | Meyle HD tie rods | ST coilovers | 750# Hyperco rear springs | Bilstein B8 rear shocks | S4 rear brake swap | Mk2 TT Turbines w/Pilot Sport AS3 | Blizzaks for snow
    -Plans: 155k and going...
    Jun 27 2011
    You're nuts! V-10 > V-8 always.
    Also pretty sure tuners have built those V10s up to completely nutty HP figures (flying mile runs and whatnot) so theres definitely aftermarket support. If you have $$$$.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    There was a s4 avant over in the s4 section that had the swap done. I think the guy that did swap and the guy who actually did the work were going back and forth about it because he was taking credit for it or something like that.
    Jun 17 2013
    jersey city nj
    I'd consider a swap like this http://www.audizine.com/forum/showth...6-Single-Turbo out the AZZ........
    Mar 24 2013
    Oakdale, CT
    Considering there is no intake manifold on that motor, you need to add $1700 to the cost right off the bat. Then you need the ecu and harness and accessories. Custom headers would likely be required also, there's $4k right there unless you make then yourself.
    -Adam
    Mar 13 2007
    I already have a build 2.7t bored to 2.8 going into a B6 avant, so I want something different with this one. Either an RS4 motor, to make the clone nearly 100%, or something just as awesome. A 3.0T is not out of the question, I just need to do a bit more research. A built 4.2 with a blower or some sort of turbo setup is also an interesting idea.
    -Tim
    Active Member Two Rings A4Trico's Avatar
    Feb 13 2016
    Richmond Hill Ontario
    If you got the money hey anythings a good idea, start a build thread!
