Results 1 to 16 of 16
    Oct 24 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    Xtool for parking brake retraction
    As the title says, How do I use Xtool to retract the parking brake to change my rear pads?
    I have done a search and can't quite find the answer. Can anyone assist me please?
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
    Oct 24 2006
    Houston
    Please.
    -Beck-
    2003 A6 2.7T Silver
    Mar 21 2015
    I'm lazy right now and don't feel like searching. What is an xtool?
    Oct 24 2006
    Houston
    http://www.audizine.com/forum/showth...M-replacement)
    It is a VAGCOM replacement for about $60 except the user interface is not as nice. What is great about it, is that it is portable and you don't need a computer to run it. You can just throw it into your glovebox or trunk and have it with you always.
    -Beck-
    2003 A6 2.7T Silver
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I don't know many people that use it, since mostly everybody just buys a VCDS cable. You might have to just explore the interface until you find some kind of E-Brake Diagnostic piece.
    Oct 24 2006
    Houston
    Maybe if someone lays out the steps on the VCDS I can follow them on xtool.
    XTool user interface is not as nice as VCDS, but the steps and codes are exactly. The same.
    -Beck-
    2003 A6 2.7T Silver
    Mar 21 2015
    Theres a vid on you tube and directions on ross tech website for parking break release.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Just get Carista, super user friendly.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Quote Originally Posted by fitzydude View Post
    THIS!
    Mar 21 2015
    You need to be running beta for PB release though.
    Oct 24 2006
    Houston
    Thanks. I found it. Awesome.
    Open Rear Parking Brake
    Prerequisites:
    Connect a battery charger as per repair manual, click photo to enlarge.
    Some A6 vehicles do not have the battery charger hook up points under the hood. If so, look next to the spare tire. Click photo to enlarge
    See Special Notes
    Cycle the Parking Brake ON, then OFF first.
    [Select]
    [53 - Parking Brake]
    [Basic Settings - 04]
    Group 007
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The brake calipers will then open, allowing the pads to be changed.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Turn ignition off.
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
    The caliper pistons do not move back into the caliper, this is normal.
    Close Rear Parking Brake
    Prerequisites:
    Connect a battery charger as per repair manual. See Special Notes
    [Select]
    Group 006
    [Go!]
    [ON/OFF/Next]
    The brake calipers will then close.
    [Done, Go Back]
    The LED in the parking brake switch and the warning lamp in the instrument cluster will probably continue to blink rapidly. This should stop after cycling the Parking Brake ON, then OFF again.
    -Beck-
    2003 A6 2.7T Silver
    Jun 30 2014
    Hayward, CA
    did you get it to work with the xtool? I'm planning on changing my brakes this weekend. I went into 53 parking brake -> basic setting, when I typed in the group number and click enter it doesn't exactly cycle, but maybe because I wasn't on a flat surface and was on my driveway. I was just trying to do a dry run.
    10 Audi A5 2.0T Ibis White | AWE Quad Touring Exhaust | AWE Down Pipe | AWE Front Mount Intercooler | high flow cat | STaTis ecu stage 1 | Eibach Pro Kit | Rs5 style grill | tinted tail lights | S5 front bumper | S5 rear bumper | S5 side spoiler | AG M580 20x10 et20 | Hankook v12 255/30/20 | 30% tint all around
    Jun 18 2015
    Cleveland
    Quote Originally Posted by Gamble52 View Post
    Just going to the group doesn't cycle. You have to set it to On or Off.
    Jun 30 2014
    Hayward, CA
    Quote Originally Posted by hotleadsingergu View Post
    that's if you have VCDS. I figured it out and will type up a how to for folks using xtool.
    Mar 21 2015
    Just posted today for your pleasure
    http://www.audizine.com/forum/showth...-Parking-Brake
    Jun 30 2014
    Hayward, CA
