    Aug 18 2012
    Tennessee
    Replace Coil Packs with spark plugs for prevention?
    Sorry if this is redundant, but after a good search and review I'm still not sure what is best.
    I have 35k on my 2012 A4 B8 so I am planning on replacing my spark plugs soon.
    ** My question is whether it is a good idea to replace the coil packs at the same time just for preventative maintenance?
    My car is running beautifully without any issues.
    Thanks in advance for any recommendations.
    2018 A5 Sportback Premium Moonlight Blue Metallic - IE Stage I ECU & TCU
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    I just had my 35k service done. They replaced just the spark plugs. I don't see a need unless you want to upgrade.
    Pedal Responce first responder.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by 4ringnut View Post
    What he said. There's no need to replace the coil packs unless they go bad or you really want the red tops.
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    If you want to be proactive and have optimal running coilpacks (as they do wear over time), sure. Once every 35k miles adds $80 to the total cost of maintenance. Otherwise, you can replace as they die (always carry a spare or two in the trunk!).
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    I got them as a set deal, ~$110 for 4 r8 coils and 4 ngk's so I just replaced them both
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
