Results 1 to 10 of 10
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Looking for part number/substitute (TIE ROD LOCK BOLT)(picture included)
    EDIT: Thanks to Phill and APR_Fast I found the answer.
    REPLACEMENT BOLTS
    https://www.ecstuning.com/ES251156/?...wxKRoCD7Pw_wcB
    http://www.eeuroparts.com/Parts/4886...Rc7hoCyYvw_wcB
    https://www.ecstuning.com/ES48310/?g...WOkBoCcVXw_wcB
    I am not sure of the strength needed and obviously these are not stock replacements so use are you own risk :D
    So while changing the struts (coilovers) a while back I had a really hard time getting all the bolts loose (damn salt from the roads) and while I was attempting to get the #6 bolt (picture below) out it stripped the flat part of the arm (not sure of the technical term) where it stops the bolt from moving so the bolt now spins freely. I am looking to get a replacement bolt for the #6 (restraining bolt) that has a standard head on it.
    Any ideas on this or if anyone knows the thread/length/pitch of the bolt?
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    There is a pretty good thread posted recently about removing the pinch bolt without a torch or ruining your control arms. I think the info you need is posted there.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by james12lucy View Post
    The problem isn't removing it, its that I stripped out the part thats stops the flat spot of the head on the #6 bolt, so now I have to use a vice grip to take the bolt out. I want to replace the bolt entirely.
    Oct 16 2008
    South Florida - Ft Lauderdale
    M10x105x26
    Phil
    Aug 17 2013
    Rossford, Oh
    M10x105x26
    Phil
    Thank you sir. I have found numerous kits with the bolt in them but nothing showing the exact sizes. Not to keep asking but any idea on the strength needed?
    Oct 16 2008
    Quote Originally Posted by yeoj112689 View Post
    Sorry no data
    Phil
    Aug 17 2013
    Rossford, Oh
    I found the bolt right after you posted lol.
    https://www.ecstuning.com/Audi-B7_A4...ckle/ES472522/
    For any future reference people may need. It however says its M10x50, is the information on the site incorrect?
    Jul 11 2015
    Los Angeles, CA
    If you're talking about the tie rod pinch bolt then yes it's m10x50. fly300kts is referring to the upper control arm pinch bolt
    edit: just saw your edited title
    | 07 Daytona Gray RS4 - SOLD |
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by APR_Fast View Post
    HA! Either way the help is appreciated by both parties. I will be looking for a new standard (6 point head) bolt to replace it because the flat side simply doesn't catch anymore. Also it is a good way to tear up your hards using vice grips.. ask me how I know.
    Thank you guys both.
    REPLACEMENT BOLTS
    Jul 11 2015
    Los Angeles, CA
    Torque setting on the self locking nut is 45 Nm (~33 ft lbs)
