Results 1 to 14 of 14
    Senior Member Three Rings Delmed83's Avatar
    Feb 19 2013
    Remove the plastic sleeve from H&R OE Sport springs before installation?
    Some people say to leave it on, some people say to take it off. I couldn't find any B8 A4 threads about it. I also read that people in northeast should remove them due to water build up.
    Also.....lettering right side up?
    Black 2013 B8.5 A4
    Previous rides:
    Silver 2001.5 B5 S4 - EPL Stage 3
    Black 2001 B5 A4 - Dahlback Stage 2
    Black 2006 B7 A4 S-Line APR Stage 2+
    Dolphin Gray B7 S4
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Leave it on, it's to prevent spring coil on coil rubbing noise. Doesn't matter which way you install them but yes most people put the coils that are closer together on the top.
    Feb 19 2013
    Thanks.
    I have the non-sport bump stops......is trimming required for these? The instructions that came with the springs did not have audi listed as one of the vehicles whose bump stops should be trimmed.
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Quote Originally Posted by Delmed83 View Post
    Thanks.
    I would recommend it so you don't ride on them. It will be very bumpy. I also don't recommend using your stock non sport shocks.
    Pedal Responce first responder.
    Feb 19 2013
    OK. My problem is this.....I bought a used B8 sport suspension (sport shocks + sport springs) but decided to go with the H&R springs instead of the sport springs. The used sport suspension set I got only came with the front sport bump stops. The rear sport bump stops are not with the set. So I guess i was just gonna trim all the stock non-sport stops and reuse those.
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Apr 04 2015
    Woburn, Ma
    I would honestly just use the sport springs. Unless you're looking to get a little lower.
    Feb 19 2013
    Too late....already got the H&R's. Yeah I want it a little lower....plus the spring rates did not match up.
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Feb 06 2012
    Allentown, PA
    If you have the factory sport shocks it will ride fine, non-sports shocks will be bouncy. No need to trim bump stops.
    Stage 1 more than you RS3
    Apr 04 2015
    Woburn, Ma
    I'll buy the sport springs from you. Pm me.
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by o1turbo30v View Post
    He's has the non sport bump stops. He 100% has to trim them, or he will constantly ride on them. Speaking from personal experience here.
    Feb 19 2013
    I have the sport shocks as I bought a used set. I only have the front sport bump stops, though. I called my local audi dealership and ordered the rear bump stops. The bump stop dust boots are the same for sport and non-sport, correct?
    4ringnut, the weight ratings for the sport springs I have are:
    Front - 0JE - Weight Rating 5
    Rear - 0YJ - Weight Rating 7
    You still want em?
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
    Apr 04 2015
    Woburn, Ma
    I'll have to double check the numbers I assumed you were sure they were B8 sport springs. If they in fact are, then yes.
    - - - Updated - - -
    Yes on the dust boots
    Apr 04 2015
    Woburn, Ma
    What color markings do they have?
    Feb 19 2013
    They are B8 sport springs.....and I gave the weight rating codes.
    Fronts - violet, pink, pink
    Rears - green, grey, white, white, white
    Oh sorry i screwed up my previous post. The rears are weight rating 9, not 7. 0YJ
    Black 2013 B8.5 A4
    Previous rides:
    Dolphin Gray B7 S4
