https://store.034motorsport.com/034m...djustable.html
Anyway, after having it installed for a few years and maybe 75k miles, it developed a failure of the bushings. Some looseness and rattling over bumps that I first thought was a bad stabilizer link, but was actually worn bushings. I contacted 034 to inquire about where to get more bushings, as they do no list replacement bushings on their website. I specifically inquired if they were using an off-the-shelf bushing that I could acquire myself, perhaps locally. They did not give me that information, but were nice about getting me a price on a custom order for just the bushings. The price was $26 shipped. Not bad.
I did inform 034 that I would be a little bit upset if I determined these were something that were available to me locally and cheaper. For one, I would be paying more just because they have secret information and I'm in the dark, which makes me feel more like a mark than a customer. And secondly, because I would be needlessly waiting on cross-country shipping from California when I could have had the things that afternoon. Turns out that I am slightly upset because they were indeed available locally AND cheaper. I don't feel like I got gouged, but I do feel like they were not up front with me, especially when I specifically asked them to be. I understand they are under no obligation to give me that information. I also understand that I am under no obligation to keep their secret. ;)
So, for any others that need replacement bushings, I am sharing the numbers:
- Energy Suspension bushing kit 9.5161G (or 9.5161R, if you want red bushings). These are the exact, greasable bushings that 034 provides. You also get free brackets that you won't use.
- Alternative is Energy Suspension kit 9.5129G (or R). These are non-greasable type. I believe they may be a little more compliant. I haven't tried these yet, but they should be a direct fit.
I found these kits available from $13 shipped. And one reseller - DST - sells them for $22 shipped with a free lifetime warranty. Here's that link:
http://www.energysuspensionparts.com/9.5161#2681
Do note that the initial run of 034 bars used different, much thinner bushings, along with an aluminum spacer plate to move the bar away from the subframe:
The bushings I describe in this thread are the updated, thicker bushings that use taller brackets and do not require the spacer plate:
