Results 1 to 9 of 9
Thread: Jumping oil cap
    Established Member Two Rings yasiu_k's Avatar
    Mar 24 2015
    Yamaha FZ6
    Jumping oil cap
    Hi, I would like to know if there is any problem, or it is just normal. I attached video
    I replaced breather hose with 034Motorsport last week. thank you for any ideas.
    Sent from my SM-G900V using Tapatalk
    Oct 03 2015
    West Hartford, CT
    came to see a jumping oil cap, was not disappointed.
    thank you for delivering OP !
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Looks normal. As the pistons move up and down they displace air underneath them which causes the oil cap dance. Overall there is slightly more vacuum which keeps the cap in place.
    Feb 13 2004
    Silicon Valley, CA
    screw the oil cap on all the way.
    Kevin - Moderator, Audizine
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Stubek View Post
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I once had a TDI that I could have dried my hair with the air coming out of the oil cap.
    Some dancing around is expected, but too much is bad.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Mar 24 2015
    Yamaha FZ6
    Thank you for info:)
    Feb 13 2004
    Silicon Valley, CA
    Quote Originally Posted by yasiu_k View Post
    I'm a little serious. If the oil cap is not screwed on, it makes sense for that to be happening as stated above with the air displacement that should be happening. From your original post, I can't tell if you just set the oil cap on there to see what would happen or if you opened your hood while the engine was running and found it like that.
    Mar 24 2015
    Yamaha FZ6
    I just set it up for video. When I had old car (Deawoo Nexia) few years ago, I heard that - there is a problem with pistons rings (maybe it is just a myth ) and they don't holds compression, but my car runs fine. Just want to know and ask you guys with more experience audio cars.
