So a while back I bought a used k03 locally, it actually seems in really good condition, but I'm rebuilding it anyway. Anyway I was a little bit confused about what I saw on the hotside wheel:
Its sort of pinkish/white fairly hard but scrapes off with a small flathead. There was also a ton of black coking/buildup underneath that ring flange thing between the wheel itself and the chra that scraped off really easily. My thought being the bearing section was seeping oil when it was being used previously.
But what about the pink stuff? I assume its coolant. You thing the CHRA was leaking coolant AND oil? I plan on getting the it media blasted to clean it up because I would imagine that gunk would really affect the balance and efficiency of the turbo. So its not a huge deal, just curious if anyone has seen this before and what the cause ended up being?
