Results 1 to 4 of 4
    Aug 25 2015
    A4 B7 Quattro S-Line, VW Jetta SE
    Champaign, IL
    Angry Locked out while engine running. TSB not helpful
    So I've been locked out 3 times now while the engine is running on my 06' B7 A4. Found this Technical Service Bulletin 2015226/3 that describes the problem perfectly.
    http://www.revbase.com/BBBMotor/TSb/...dPdf?id=155794
    When I open the door after driving some distance the central locking system doesn't unlock the doors.
    It says to replace the driver door lock and both door control modules in the front. Wondering if anyone has had this issue and tried this fix.
    Stealership wants this for parts
    Lock: actuator- $256.76 8e1837015ab
    Left Control module $252.50 8e1959801g (CONTROL MODULES CONNECTED TO THE WINDOW MOTOR WTF?!?!)
    Right Control module $252.50 8e1959802g
    And if I buy these parts used, who knows if I will get the updated software/hardware because they won't give me a serial number break or a software number.
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    There might be a slightly cheaper fix (ie. free)
    When exiting the car - for any reason or length of time - the engine is not running and key is in hand.
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Jun 17 2013
    jersey city nj
    Since the car is running anyway when you leave the car. Roll a window down
    Oct 23 2015
    Australia
    Quote Originally Posted by vce1232000 View Post
    After being locked out of a Hyundai I-load rent a car in a remote part of the Northern territory of Australia with everything we had inside ! I will never shut a car door with the engine running or key in ignition ( with no-one inside obviously ), I had to smash the quarter vent,luckily insured.
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
