Thread: Actual Boost?
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Thumbs up Actual Boost?
    VAG COM logs show that my actual boost is 2540 mbar. when i convert this to PSI it says around 36 PSI, is this forreal?? am i actually boosting 36 PSI??? the answer is probably no but could someone tell me what i am actually boosting? Thanks!
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by 123lilc View Post
    actual boost is inclusive of atmospheric pressure, so you need to subtract that out. Also, 2.5 bar is the limit of the stock MAP sensor, so your actual boost level may be higher.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 04 2015
    Champaign, Illinois
    Quote Originally Posted by Matt Devo View Post
    so my boost gauge reads around 30psi is this accurate? (mechanical)
    also is it possible to upgrade my MAP sensor so it can read higher readings?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Read the boost pressure at idle, and then subtract that amount from your actual boost. In Houston the atmospheric pressure is 990mbar. This will change dependent on elevation.
    2019 SQ5 Prestige
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    We have no way of knowing how accurate your boost gauge is. You can always try a different one and verify.
    Yes, there are tuners who are willing to incorporate a different MAP sensor. For example, I'm planning to install the VW 3bar MAP sensor when Motoza is read to incorporate it into my tune.
    From what I understand, though, it's a decent amount of work due to the ECU's stock 4-bit limit for the MAP sensor (anything greater than 2.5bar requires tweaking to the way the 4-bit limit is used, or something like that).
    3bar MAP will allow the ECU to see up to 29psi at sea level. They have a 4bar (43.5psi @ sea level), but not sure if there is a 3.5bar.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
