Results 1 to 10 of 10
    Dec 13 2014
    columbus
    Whistle upon acceleration?
    Car boosts just fine, no loss in power, no CEL, all hoses tight and checked for air leaks recently with the A4 mods tool, someone said it could be a transmission issue, hopefully not, my car shifts just fine, clutch is fine. Pretty confused, any ideas?
    - - - Updated - - -
    Only seems to be occurring during boost, not if I just sit and rev my engine. 03 Audi A4 1.8t
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Try and get a video clip and post it up. No way someone can diagnose a noise without hearing it.
    Dec 13 2014
    columbus
    Quote Originally Posted by xalents23 View Post
    It is way too faint to be able to get a good video of it.
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    ...could it be the turbo?
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Quote Originally Posted by treysgreen View Post
    I was thinking the same
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Boost leak.
    2019 SQ5 Prestige
    Oct 02 2006
    Wadsworth,OH
    Any intake mods? High flow filter? Turbo inlet pipe?
    Have you checked the compressor wheel for shaft play? By removing the headlight you have good access to the turbo inlet pipe which can be loosened enough to slide out of the way and give the compressor wheel a wiggle.
    Jason
    Mar 11 2012
    Audi A5
    Ventura, CA
    I would put money on it just being turbo whine.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Established Member Two Rings Detroiter's Avatar
    Apr 05 2015
    Michigan
    ^I'm with Sauci, sounds like it could just be the turbo spooling up to me too. I get a pretty audible spooling sound once hitting boost on mine although I do have a custom intake though.
    Senior Member Two Rings Rus_ninja's Avatar
    Nov 30 2013
    I cant hear anything over the sound of my exhaust, damn you all!
    B6 A4 Avant 1.8T 6-Speed / Motoza tuned FrankenTurbo F21L / 3" MAF / Bosch EV14 550cc / Solo Werks Coils / 034 HFC / 034 Engine Mounts / 034 Sway bar / 710n DV / RA4 Stage1 Clutch / Apikol Snub / Apikol SMIC / Magnaflow 16601 / B7 S4 Brakes
