Results 1 to 19 of 19
    Popping out of gear
    Hey all,
    Started having a problem few days ago, car started popping out of third gear, now it does it on reverse, 1st, 3rd and 5th. Any ideas? Searched and i cant seem to find much, guessing linkage or tranny mount.
    Dec 10 2013
    Borden, Ontario, Canada
    Synchros is my guess. Time for a rebuild
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    Has the shifter ever been changed or messed with? Clutch/tranny been removed? It's possible the shifter needs re-aligned, but it's also very possible the synchros are starting to fail as mentioned above.
    Look up JHM's shifter alignment video, it's very helpful, you'll need an angle finder tool.
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    Check your shifter alignment before looking into a transmission rebuild. You don't NEED an angle finder tool. I installed my short shifter without one. Just keep adjusting it until you can get it into all gears. If your shifter still pops out while driving, then it's most likely a synchro issue.
    Sep 30 2006
    Missoula, MT
    The angle finder costs like $5...and saves you a ton of guess work.
    Kk ill take a look, funny i just bought an angle finder today for some reno projects. Thanks guys all helpfull, i was hoping it wasnt the synchros, fingers crossed.
    Just a side note before I start taring into this, rev, first, 3rd and fifth definitely do not go in as far as they used too and 2nd, 4th and 6th go quite a bit further back then before, tranny hasnt been out in almost 2 years now, before i bought the car, i would like for it to last until summer, new audi and vr6 swap is going in the ol girl.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    the only thing that holds the gears in place are the detents...they work around the collars to hold it in gear, i'd say detents are a possibility and since its all the gears that are forward in the pattern and not the gears the correspond with the collars (1-2 3-4 5-6). i'd check there first. before opening it up. detents are cheap. and easy to replace.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    So I took her apart to have a look too see if i could adjust it any, no go, it's already at it's max position. Is this normal? It's missing 1/8th of an in to stay in gear.
    Sep 11 2009
    NE
    you're adjusting wrong thing if you're touching top bolt visible in pic. leave it alone, e.g. reset for middle (it is used to move whole shifer assembly forward/backwards for better ergonomics, you have to experiment with what works for you the best) and then align the bottom bolt on rod that moves around when you move the shifter.
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Yeah, put the top bolt back to the middle.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Thats how it was when I opened it up, i tried moving it back to centre and adjusting like jhm but it seems to be worst.
    May 16 2008
    South Texas
    Likely mounts or shifter.
    Thats good news, my mounts are sloppy
    Sep 11 2009
    NE
    You said this: So I took her apart to have a look too see if i could adjust it any, no go, it's already at it's max position. Is this normal? It's missing 1/8th of an in to stay in gear.
    This tells me that you're touching wrong bolt.
    Again, reset top (black forward bolt in your picture, bolts to static not-moving rod) bolt to middle, fasten it down and then undo bottom bolt (silver, on a rod that moves when you operate shifter) and adjust shifter until you get all gears going in, this is where the angle gauge comes into play.
    Yes I have done that, but putting the top bolt to middle pushes the shifter assembly too much forward which doesn't even let any of the top gears engage, doesn't matter how I adjust the second bolt. The PO rebuilt the motor and thats how he had it adjusted when I bought the car, its been the same way for nearly 2 years now never had an issue, I will admit I have been running it hard enough with the snow we've gotten up here.
    http://youtu.be/207F6Rd7HnE
    Sep 30 2006
    Missoula, MT
    Again, $5 angle finder and JHM video, you would have been done with this a week ago.
    I must be watching the wrong video or my angle finder is broken then lol
