Results 1 to 13 of 13
    Mar 21 2015
    Stage 2 b5 s4
    Minnesota
    wtb 1.8t longblock with rods
    Looking to buy a 1.8t longblock with rods. Must be ethier aeb,awm, or an atw. No more than 130k miles. Im from mn can drive up to 10 hours for the right one.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You should be a little more specific about which block, 058 or 06a. Guessing you want 058 due to your name.
    What part of minnesota? Why don't you just buy a spare engine and put rods in yourself?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Mar 21 2015
    Stage 2 b5 s4
    Minnesota
    Sorry, i figured by giving the engine codes that was specific Enough. It dosent matter what block. 058 or 06a just needs to be aeb, awm, or atw. And im about 30 mins west of minneapolis. Ive never put rods in an engine before and im nervous so i was hoping to find a partout with rods.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    I'm guessing redline asked about block because AEB and ATW use 058 block, while AWM uses 06A block. 058 and 06A blocks aren't interchangeable when it comes to external items such as the AC compressor, some sensors, etc.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    sign up for mnaudi.com, or contact the guys at anderson motorsport in chanhassen. they may have a rodded long block sitting around.
    Edit- scratch that idea. just talked to someone and said all he has is a built 06a. Swapping to that would be a lot of work and extra parts. I'll keep an eye out for you. Or maybe you could contact them and ask how much it would cost for them to put some rods in for you? If you stick with stock pistons it wont cost very much.
    2000 S4- Working?
    Mar 21 2015
    Stage 2 b5 s4
    Minnesota
    Yeah on second thought i decided i dont really want to swap to an 06a. The car its going in is a 2000 a4 quattro. And i thought since its an 058 block you cant use factory pistons with aftermarket rods?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Sure you can. If reusing stock pistons, you will need 19mm IE rods
    2000 S4- Working?
    Feb 02 2016
    Salem, SD
    I'm south of you by Sioux Falls, SD, I'd be able to get you whatever you need, have a stockpile of awm and atw 1.8t engines. This Monday I can go over everything and check all the rods and valves to make sure everything's straight and clean.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by B5Aura View Post
    He wants a block with forged rods
    2000 S4- Working?
    Mar 21 2015
    Stage 2 b5 s4
    Minnesota
    Redline, i thought the oem 058 had 20mm wristpins and id need 20mm rods?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by 1.8taeb5speed View Post
    Only AEB piston. ATW and AWM pistons came with 19mm pins.
    I want to clarify that if you by aftermarket pistons for any block, they will need 20mm pins. The only block that came stock with 20mm pins is AEB, but you can use AEB pistons in any 1.8t block.
    2000 S4- Working?
    Mar 21 2015
    Stage 2 b5 s4
    Minnesota
    Thanks redline! So then i have a question, if i bought a 1.8t aeb with under 100k miles and then bought rods and a rod install kit wich includes rod bearings, head bolts, and head gasket and installed it would that be acceptable? I want to go the cheapest route possible while still being Reliable and able to support 300awhp.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That would be fine, just get some pistons rings.
    Also, don't get one of those complete kits. They come from less than desirable companies. I would piece everything together. You should be looking at about $1000 in parts. Don't forget about intermediate shaft bearings too. Maybe an oil pump, but it isn't a huge deal. Also need main seals, thrust washers, probably a couple things I am forgetting,.
    If you really don't trust yourself putting it together, you will have to have someone else do it. Guessing labor would be around $500.
    If you really wanted to, I could probably install everything for you, but I would want everything delivered to me so I dont have to go anywhere. I'd do it pretty reasonably, maybe $200 or so. Just have to talk my buddy into it. Let me know. I'm in the St. Cloud area.
    2000 S4- Working?
