Has anyone else run into this? Coils are adjusted to the point of adding preload and it is too low to drive. Hoping you guys can think of something I haven't.
I started with the coils all the way down front and rear because that's usually where I end up leaving them on other cars. I set the car down, adjusted camber in the rear and camber/toe in the front (SPC upper control arms) into the neighborhood of proper alignment. I've already trimmed the fender liner and "convinced" the fender well to clear the SPC arms at full suspension compression. It was super slammed (see pic). Honestly I know it looks fantastic as is but it's lower in person than it looks in pictures. If I turn the wheel halfway to lock the tire hits the fender. No problem, put it back on the lift and raised the front perches in small increments, but finding no increase in height each time I set the car back down. Finally got to the point where I was adding spring preload and it had barely raised the car. Maybe not at all. Other than adding washers between the front top hat and fender I can't see any simple way to get additional height out of this setup. Hope you guys can help. Thanks!
Tom
