Results 1 to 25 of 25
    Dec 08 2015
    Calgary
    MMI turns on and shuts right off??? HELP
    Anyone have this issue were your MMI turns on and the just shuts right off only started happening once my battery was replaced and coded into the car ? is there a fuse or is it the MMI system or amp i have been looking online for a bit now
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by armatowa View Post
    Do a search for "MMI reset" I just do not remember the 3 keys you need to hold down together.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Aug 25 2008
    Boston, MA
    I had this same exact issue when i bought an MMI off ebay. Turns out it was a corrupted HDD and the unit would not boot into QNX (our MMI systems utilize QNX RTOS).
    There is a chance that the battery swap may have done the same (worst case scenario). Just my $0.02.
    Aug 25 2008
    Boston, MA
    How to hard reset.
    Dec 08 2015
    Calgary
    Did hard reset and no luck boys
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Are you sure that the battery was coded properly via VCDS? Maybe your car is going into low power mode because it thinks the battery is drained.
    Dec 08 2015
    Calgary
    Brand new battery from Audi I watched them code it using VCDS
    Aug 22 2014
    bloomfield,ct
    TAKE IT BACK TO them, if problem only came after new battery
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Mine did the same thing but it needed a software update.
    Aug 25 2008
    Boston, MA
    Quote Originally Posted by jygesq View Post
    this.
    /thread
    Dec 08 2015
    Calgary
    I did I called dealer the said it sounds like a fried AMP or HDD in MMI is burnt but will test it thursday
    Established Member Two Rings Mtr24's Avatar
    Dec 24 2011
    New York, NY
    Check for sticky buttons
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2009 Ibis White A4 2.0T AT: 20% Tint - APR Stage 2+ - Eurocode Rotamass LW Crank Pulley - SPM HFC & Downpipe (removed and for sale) - AWE Quad Tip Catback Exhaust w/ Black Diamond Tips - ST Coilovers - Gloss Black RS Style Grille - VMR v718's 19x9.5 ET45 - 5mm Spacers - J-Codes
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Hey all - thought I'd tag along here (2010 A6 w/3G MMI Nav). Having the same problem this morning - no battery change or temp/liquid causes. No sound and no lights on the buttons. Interestingly, when I hard/force reset it, it comes on with the splash screen and then dies after about 3 seconds.
    I don't know much, but I believe this means it's getting power fine and receiving signals from the buttons just fine. Anyone have any thoughts? (Will scan when I get home tonight). Thanks in advance!
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Senior Member Three Rings trip'n's Avatar
    Dec 28 2009
    2000 B5 S4
    2010. so my Sirius was not connecting last night, car switched to FM on its own and now Sirius is Gone, as in not on any screens, like the car deleted it or as if the car never had it in the first place.
    Everything else works 100% normal. Car was in for a oil change at my shop but can't see how a scan jacked anything.
    Anyone have a clue? I'm about to do a hard reset-
    Thanks
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    try pulling the fuse or disconnecting the battery for a bit?
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Established Member Two Rings Joelito18's Avatar
    Apr 15 2018
    Queens, NY
    Having the same issue, dash and mmi were shutting off this week and pulled the codes which were for low voltage. Replaced the battery and the mmi now randomly shut off but radio kept working fine. Re started the car and all is fine. Haven’t had a chance to recode the battery yet. Did you guys ever figure what was wrong?
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Never recoded my new battery or had any issues post replacement
    Nov 20 2013
    Montreal Canada
    Quote Originally Posted by maga4 View Post
    Hey sorry to necro bump. I have the same issue. My infotainment comes up for a few seconds on the loading screen then shuts off. Also no lights or sound. How were you able to fix it?
    Thanks in advance.
    Sent from my SM-G973W using Tapatalk
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by mantech4 View Post
    Thanks in advance.
    buy optical loop and test modules one by one, one must be dead, just in case fuse check first!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Aug 14 2011
    Stamford, CT
    Thanks in advance.
    mantech4 - Having identical issue. Did you find a resolution? I tried a replacement MMI control module which resulted in the same issue - screen lights up for a few seconds and then shuts down.
    Before this happened, I had a dead battery so I had thought related to this, however my independent repair tells me no. I am not so sure. They tried a battery hard reset but did not help. Any info sincerely appreciated!
    Thanks
    Nov 20 2013
    Montreal Canada
    Quote Originally Posted by njg123 View Post
    Thanks
    Unfortunately no idea... Tried to replace amp and radio module in the back of trunk but now it doesn't even turn on... Might I'll just buy a Rsnav.
    Sad...
    Senior Member Two Rings celticsevad's Avatar
    Jan 23 2019
    Montreal.Canada
    Audi S4 2011 DSG -Topspeedauto reinforced Testpipes ceracoat+wrapped , Xpipe , airbox w RKXtech silicone inlet hose,
    Crank pulley 206mm KI , 7pk1355 belt, custom HX made from a bmw E36 ebay alu radiator and divorced system
    Custom made 50/50 water meth 960cc
    Neurotuning.ca tuned, im French canadian
    [email protected] ICAR Mirabel stock
    [email protected] with mods
    Goodies: DIY BoostGauge, RSNav, S4 courtesy door lamps, trunk HK Carbon spoiler, ADE creation front splitter=Facebook.com/ADE.creatiions/
    Apr 08 2014
    Quote Originally Posted by celticsevad View Post
    The newest apple ios13.2 fixed my problem.
    Dec 03 2024
    Englewood, CO
    Sticky button solution
    Sticky button (used tip of a knife to lift it up) suggestion solved it for my 2008 A6.
    Thank you!!!!!
    Mar 21 2011
    B8.5 S4 6spd
    NJ USA
    Quote Originally Posted by VanillaGorilla72 View Post
    Thank you!!!!!
    Are you really posting a fix for someone that posted 5 years ago? LOL
