Results 1 to 3 of 3
Thread: Fuel Pump Issue
    Active Member One Ring Meyek66's Avatar
    Apr 07 2014
    2011 Mercedes C63 AMG
    Longmont
    Fuel Pump Issue
    I went to start my car today and all it did was turn over. I feels like the engine isn't getting any fuel and I also noticed that when I open my doors the fuel pump isn't priming. The fuse is fine from all that I have read on these forums is that the fuel pump has been an issue with a lot of owners. Does anyone have a procedure for this?
    Thanks everybody.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Quote Originally Posted by Meyek66 View Post
    Thanks everybody.
    How many miles on the vehicle and when was the last time, if ever, you changed the fuel filter?
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Veteran Member Four Rings Unit1Evangelion's Avatar
    Oct 10 2009
    Rogue gym equipment and tools to make me feel manly.
    Texas
    Thanks everybody.
    As Cookiemonsta said, check the fuel filter. Replace it if its been over 10k miles just to make sure. Have you checked any of the codes? If so, can you post them?
    If the fuel filter doesn't fix it, remove the back seat, on the passenger side is your low pressure fuel pump which could be your problem. If you remove it you can check for any debris on the inlets which could have caused it to go out. Also check the other side which could be clogged as well.
    "What you do in life, echoes in eternity."
