Results 1 to 13 of 13
    Feb 07 2016
    Flushing NY
    Wrong door open on display?
    I just got my b6 s4 over the weekend and I noticed that every time the drivers door is open it shows the passenger side on the cluster display and vice versa... Does anyone know how to fix this issue??
    Established Member Two Rings adf's Avatar
    Aug 25 2015
    GT3 Touring
    California
    Mine does this as well. I think it started after I disabled the seat belt chime and added remote windows up/down via this --> http://nickscarblog.com/cars/must-ha...6-and-b7-audis
    Either way, the car seems to think it's right-hand drive. Possible that mucking about with the region settings in VCDS did this. I haven't rolled back the codes to verify though.
    2007 S4 Avant 6MT, Dolphin Gray, APR Exhaust, 034 motor mounts, control arms, rear sway
    2019 GT3 Touring
    gallery
    Jun 07 2013
    West
    Just visualize the image of the car as seen from underneath. Problem solved. You are welcome.
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    ahaha, mine too!
    slow is fast...
    Feb 07 2016
    Flushing NY
    Lmfao... Concavitor!! Anyone else have any ideas how to fix this?
    Jul 28 2008
    Everywhere
    Adf had a good point. Change the region of the car and it should be fine. You gotta use vag com
    Feb 07 2016
    Flushing NY
    I am a total noob with Audi/vw... Have any idea how I can fix it through vag com?
    Jul 28 2008
    Everywhere
    Quote Originally Posted by DGM S4 View Post
    I am not sure what the coding is on your car, but open vagcom, go to instruments, click coding, and the 5th digit should be 2
    00xx?x1: Country
    0 = Germany (D)
    1 = Rest of World (RoW)
    2 = USA (US)
    3 = Canada (CAN)
    4 = Great Britain (GB)
    5 = Japan (JP)
    6 = Saudi Arabia
    7 = Australia (AUS)
    Feb 18 2014
    Arizona
    Quote Originally Posted by adf View Post
    I've made those two changes and i don't have this problem. I haven't changed the region, though, which I believe would be done if you wanted to change the way the headlights and foglights work, so I'm guessing that's the culprit
    Feb 07 2016
    Flushing NY
    So I finally got to check this and it does indeed show USA in recode... Any other suggestions?
    Aug 25 2015
    GT3 Touring
    California
    Bump. I am sadly unable to fix mine either in vcds. Stumped.
    2019 GT3 Touring
    gallery
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    I'm bringing this back to life here since I'm having the same issue and think that I reverted everything back to what it once was, but the front doors are still reversed.
    If anyone fixed this, please let me know how and what you did.
    Currently, I'm hoping that I have an eeprom dump of the cluster stored from a time prior to making this change and a reflash will revert it back....
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Jan 11 2005
    Pittsburgh, PA
    Update if it matters to anyone. I fixed this by recoding the Central Convenience module via the long coding helper. I had a RHD option checked and removed this. Back to normal.
    Steve
