Results 1 to 2 of 2
    Active Member Two Rings Kyüshutsu's Avatar
    Jul 28 2013
    Minnesota
    HELP!! Output Shaft Flange questions
    Can someone tell me if there is a difference between the output shaft flange for the manual trans and the output shaft flange for the automatic on the AWM engine? The compatibility chart for the 2001 1.8t quattro shows automatic trans but for 2005 it shows manual trans..
    I came across this on Quattroworld:
    http://forums.quattroworld.com/a8/msgs/32544.phtml
    The part number 01V-409-809-A .
    Here is the link to the parts listed on europaparts.com.
    https://www.europaparts.com/output-f...p7mhoCbXnw_wcB
    Jul 28 2013
    Minnesota
    BUMP
