Results 1 to 29 of 29
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Seriously..... Just bought a 05 B6 and then..
    So my b5 had some timing belt issues which caused teeth to jump 13 teeth to the right (TDC lined up on crank)
    So I went out and bought this...
    Now just leaving my lot... Sitting there before leaving actually I hear a nose followed by battery light.. So I quickly shut off the car..
    Sure enough.. Timing belt was loose.. Scanned it no codes came up and pulled all plugs and couldn't see any markings like I could on the b5.
    Do you guys think the engines ok and to buy a timing belt kit?
    Or could there be more?
    Sent from my A0001 using Tapatalk
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Oct 29 2005
    10speed
    San Francisco, CA
    Sounds like you bent valves regardless.
    - Clint
    Jun 30 2008
    Erie, Pennsylvania
    So your A4 stalled and you *didn't* immediately hit the key to try and restart it?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If the tbelt slipped, you bent valves.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jun 06 2008
    Port Moody, Canada
    Heard a noise, saw the battery symbol on the dash and shut it off.
    Car was at idol the whole time.
    Jun 06 2008
    Port Moody, Canada
    Quote Originally Posted by redline380 View Post
    Wouldn't that throw a code and do what my b5 did... Stamp marks on the pistons?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by J Ozzie View Post
    Well, that doesn't necessarily mean the belt is bad. If the battery light came on, I would probably inspect the accessory belt first since that runs the alternator.
    Did you peel the tbelt cover back and actually look at it?
    2000 S4- Working?
    Jun 06 2008
    Port Moody, Canada
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That looks kind of loose, but according to one of IE's diy videos, the belt should flex 90 degrees while tight.
    I wouldn't get too crazy yet. Do some more inspection first. The belt would probably be a lot worse if it let go while running.
    2000 S4- Working?
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Mine has been loose like that before. I got scared for a moment since I've been driving it like that, but then I started the car again and double checked it and it was tighter. I'm not sure what that means but I'm still driving it .
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Jun 06 2008
    Port Moody, Canada
    I scanned it and no codes came up, at this point I just don't want to risk it.
    Jun 06 2008
    Port Moody, Canada
    I'll put it this way, if I crank it to inspect it I'm sure shit will get worse. It's too loose for my likings.
    I just want to make sure I caught it in time and have no bent valves.
    Sent from my Nexus 7
    Jun 30 2008
    Erie, Pennsylvania
    Next step is to turn the engine over by hand, check timing. See if it jumped or not.
    But if YOU shut the car off (and it didn't stall itself), that means you're probably just fine and whatever happened very likely had nothing to do with the timing belt. If you are paranoid (and who wouldn't be after a belt failure on another 1.8T), then put a belt kit in it. I'd suggest the new non-hydraulic "Litens" tensioner setup. Good stuff, that.
    Jun 06 2008
    Port Moody, Canada
    I am very paranoid that's for sure, I'm thinking it was a tensioner fail... Shitty thing is I have no choice to take it to a shop cus my b5 is in my driveway and my B6 is in my bottom parking lot. There's a no "mechanics work" policy.
    The shop by me charges 105/h ugh
    Nov 10 2015
    Sudbury, ON
    I swear any time someone buys a used B6, theres always a few issues to be addressed. When I bought my USP. Battery & alternator died in first 2 days lol. Sunroof doesn't work, drivers seat down motor doesn't work. Lol the joys.
    Looks like a really clean White A4! Hopefully you didn't damage the head
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Jun 06 2008
    Port Moody, Canada
    Quote Originally Posted by jesse500 View Post
    Right, ugh.
    It's super clean, there's a few things that need done to it.. Upper control arms, valve cover gasket.. Either then that... Well. Now this issue. I've only had it 3 days....
    Jun 06 2008
    Port Moody, Canada
    Found a video on YouTube of the sound I was getting.
    https://youtu.be/KddQ8RN3dY0
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    The engine in the video is running. I agree with the above, turn it over by hand and make sure everything is ok. Maybe a compression check after that.
    Jun 06 2008
    Port Moody, Canada
    Quote Originally Posted by Captain_Panic View Post
    The video above is what mine sounded like.. Not my video.
    May 01 2015
    Dublin, Ohio
    I know. The engine in the video IS running. If yours sounds just like it, then turn the engine by hand to ensure there is no piston to valve contact. If there isn't I would do a compression check next.
    Jun 06 2008
    Port Moody, Canada
    Its going into the shop tomorrow to get a belt on. I'd do it myself but my b5 is taking my wrench spot...
    Jun 06 2008
    Port Moody, Canada
    Well, good news! I saved the B6!! Shop tech called me said you better buy yourself a lotto ticket asap! You caught it in time!! He replaced the belts, checked out the engine and all is good!
    Aug 26 2005
    Good news for sure! Thanks for the update!
    Vorsprung durch Technik
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Hope you're just as lucky with that lotto ticket
    Jun 06 2008
    Port Moody, Canada
    Next thing is to figure out how to rig up an AUX cable to the stock symphony Bose system...
    Aug 26 2005
    The best way to do that is with a Symphony II+ hu out of a B7 A4. It is setup to connect to an Aux input and has a button on the front to select CD or Aux audio source. In addition, the Sym II+ audio quality is superior to the Sym II.
    Jun 06 2008
    Port Moody, Canada
    That might be a good option here.... In refuse to go back to the "CD Case life"
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    My tensioner failed on me couple months ago, same symptoms battery light came on and steering wheel locked up on me. Drove it home with no power steering popped the hood and serpentine belt was just laying in there.
    Mar 03 2015
    Easton PA
    Ha! That's it? My B6 avant block cracked 3 months after I bought it cost me 4 grand for a replacement engine new timing job all tastes good stuff. Wife almost divorced me over it
