Results 1 to 7 of 7
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    Anyone order from RockAuto recently and have the 5% discount code?
    PLMK!
    I have not ordered recently so the last one I had expired.
    Thanks.
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Uh... Why is this in Projects & Builds?
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Aug 20 2015
    Chicago
    Quote Originally Posted by JediJoker7169 View Post
    Idk, think it was moved, i thought i put it in chitchat :/
    Aug 20 2015
    Chicago
    Could anyone send me a code please if you have it.
    Thanks
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by Arsenal2012 View Post
    Thanks
    They are all over Google at any given time. Don't even have to click anything to find it.
    MM73AR
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    another code
    Thank you for being a RockAuto customer! To show our appreciation, we have a special discount for you.
    Your discount code is:
    9274581787357097
    How to Use Your Discount Code
    Enter the code above in the "How did you hear about us" box without any other numbers or characters.
    Please note: Orders are placed online at RockAuto.com. Discount cannot be applied once an order is marked as shipped.
    The discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.
    This discount code expires on November 25, 2018, so do not wait!
    Thanks again for buying your auto parts at RockAuto!
    www.RockAuto.com
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Established Member Two Rings DreamInRotary's Avatar
    Sep 10 2017
    2001 Allroad / 1984 RXSE7EN
    Cambridge, Minnesota
    I always just Google it and use the first one that comes up, super simple.
    Allroad "411R0AD" Stage 2 Build - No Bolt Left Un-turned! CLICKABLE BUILD THREAD - 6sp Manual 01e - B7 RS4 Clutch Conversion - TTV SMF - EPL Stage 2 Tune - Arnott Bags - Hotchkis Sway Bars - True 3" to 3" SSAC Downpipes - 2.5" Magnaflow Exhaust - & Tons More! - Check out the build thread!
