Results 1 to 17 of 17
    Senior Member Three Rings itlnstallion818's Avatar
    Apr 28 2013
    Columbus, OH
    HFC o2 spacer discussion!
    I know different people have gotten different results. I have a B8.5 with an 034 HFC. I tried the 90 degree spacer, CEL. Then the minicat, CEL. It does NOT have a tune and won't be getting one for awhile (under warranty with new longblock). Any insight/ tricks? I know this has been covered but I figured it's own thread would get the most up to date answers. Thanks!
    2013 Scuba Blue A4 | S-line Prestige | AVG M590 | K&N Typhoon | VCDS | 034 HFC
    Sep 09 2010
    Destin, FL
    Well the tune would usually make that light go away but since you don't have a tune, I'm not sure if you can clear that. At least that's the only way mine went away. How much longer do you have the warranty?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    None of them work long term, you need a stage 2 tune, / end thread.
    Stage 1 more than you RS3
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Quote Originally Posted by o1turbo30v View Post
    Lol. The ignorance is real. I've had mine for 2-1/2 years. No CEL ever.
    2016 S3
    Instagram- @Thisisastickup
    Apr 28 2013
    Columbus, OH
    Quote Originally Posted by b6Hate4 View Post
    Which spacer are you using, if any?
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    I couldn't get ANY of them, not even the ones that come with difference size inserts, to work for more than about 40 miles.
    Usually the CEL was on within the first 20 minutes of driving. I spent a solid 2 months dicking with it.
    I finally gave up and had the HFC replaced with the stock one. Too much trouble and I definitely didn't want to have to deal with going back to the tuner every year before emissions testing so the readiness code would reset, but hope the CEL didn't come on before the test, which wasn't likely to happen in my case.
    Also found out that APR was going to charge for stage 1 AND stage 2, even though I just wanted to go straight to stage 2. So I said screw it... stage 1 tune will be enough.
    YMMV of course. Apparently the spacer works for some people.
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by itlnstallion818 View Post
    roc-euro. With a Eurocode HFC.
    2016 S3
    Apr 28 2013
    Columbus, OH
    edit: are you using straight, 45 or 90 degree spacer?
    Last edited by itlnstallion818; 02-08-2016 at 01:33 PM. Reason: already answered question
    Oct 27 2010
    Norwood, MA.
    45. The one with the little piece of catalyst material inside.
    2016 S3
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    you may have more luck if you use 2 spacers.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by IHave2Turbos View Post
    No, you wont. The sensor NEEDS to recieve a certain amount of exhaust gases or it will throw a code for a defective sensor if the values are too low.
    2016 S3
    Apr 28 2013
    Columbus, OH
    Thanks buddy! It's backordered but i have an order put in. hopefully this works
    Oct 27 2010
    Norwood, MA.
    No problem. The spacer comes with a retaining nut so you can set the depth. Mine is threaded in all the way and its been trouble free since I installed it. I didnt notice weather you were running a HFC or a TP, but either way good luck!
    2016 S3
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    I've got an order in for the back ordered roc-euro spacer as well. Hopefully they get some more cranked out soon. I plan on using the eurocode HFC too. Thanks for the heads up!
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Senior Member Two Rings inception's Avatar
    Mar 19 2015
    2018 Q7 3.0T
    phoenix arizona
    I had my 034 HFC way before APR or anyone had a tune for my B8.5 and I tried everything i could. The ECU is very intelligent and in some cases i have heard the CEL goes away but mine did not work. i even tried the ROC-Euro mini cat spacer but no luck.
    Only thing that worked was the Stage 2 tune. Good luck
    2018 S6 APR Stage 1
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by inception View Post
    Same, 034 HFC with 90 degree spacer back in 2011 and nothing worked.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Got this
    http://m.ebay.com/itm/191754553543
    I only get a cel once in a while. Only when its 20*F outside and i go wot in the first 10 mins of driving.
