Results 1 to 10 of 10
    Aug 15 2012
    garage items
    Montana
    Creative side mounting brackets for rs4(rep/real) bumper to s4.
    My rs4 rep bumper suffered some catastrophic damage and about 50 feet of abs welding rod later, shes ready for paint. I previously had the sides mounted using two screws going through holes I drilled in the bottom of each fender. I'd like to make a more friendly mounting system that's easier to get to and maybe even using quick disconnect pins. Obviously, I want to keep it hidden. Just reaching out to anyone with experience and what solution you came up with. Pictures, if possible, would be an extra bonus. Thanks
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Ive seen this type used and turns out pretty sweet.
    Easy to use, stout, and fairly incognito so looks good.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Nov 16 2010
    WetSide, WA
    That is impressive
    Dec 05 2007
    Been running these for a couple years now. Quality stuff!
    Aug 15 2012
    garage items
    Montana
    That's perfect, thanks!
    Here's the website for future reference: http://www.quik-latch.com/
    Junior Member Two Rings
    Oct 16 2010
    S4 2.7T - 996
    Montreal, Quebec
    Nice job !!
    I like it
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Wow.. Ive see the mod before, and wasn't really interested, but after seeing the video, thats awesome!!
    Treysgreen, I'm assuming thats your car, what size did you buy? Sorry if I missed it in the diy. And what do you still run the two allen bolts in the front grilles? or does this eliminate that too?
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    The Quik-Latches can be a decent option, particularly if you have a black or silver car where they are less noticeable, but it still detracts from the "clean" look to some degree.
    Most people aren't removing their bumpers often, so IMO it's better to just secure it with something hidden.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Three Rings MTV2002's Avatar
    Jul 08 2009
    2000 Imola 6sp, 2001 Imola 6spd avant
    Del Aware
    I'm working on this right now with my car, i like the clean look and I'm working on trying to get the quick releases mounted backwards. i have the pin epoxied to the bumper and the latch itself mounted on the metal part of the fender where the stock bumper guides were. still working on making it all work together but it will be very clean when its completed. just another option.....
    one slow(smokey) yellow turd (under construction)
    and a school bus....
